Rim size/Tire size
Old Jan 14, 2003 | 04:32 PM
IAN's Avatar
IAN
Rotary Reborn!
Rim size/Tire size
List
What would be the ideal set-up for rims on a FC.
17X8 +35mm
17x9 +38mm
I'm running lowering springs apex and tokico shocks.
This is from FC3Spro.
The fronts can go 8" wide before running into major fitment problems. The rears can easily go 9". Just watch the offset (8", +25mm to +30mm front; 9", +30mm to +35mm rear), and everything should be close. Again, tire profile has a huge bearing on if you run into fitment problems, so try and see if you can find someone who has run a similar combination of rim specs and tire models you've been eyeing. If you do run into minor fitment problems on the inside (i.e. suspension), you can use spacers to get some clearance. If you're rubbing the fenders, then you need to get your fenders rolled. Rolling your fender is the process that bends the inside lip upwards for additional clearance for your tires.
thanks,
Ian Skacel
Old Jan 15, 2003 | 12:01 AM
Cheers!'s Avatar
Former Rx7 *****
bump
ard t2 should be able to answer it exactly... i'm not sure if 17x8 +35 mm offset and 17x9 + 40 mm offset will work without coilovers... that is what i'm planning to run with jics
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
