Tranny fluid in the engine
Old Aug 12, 2001 | 02:15 AM
Alvin's Avatar
I had the same problem with my 84 GSL, it smoked badly and went thru lots of tranny fluid. It was the modulator valve that located on the left side of the tranny. You can get one from mazdatrix. The only differance from my problem was that I never show any signs of a leak. The tranny fluid was being sucked thru the engine and being burned. Don't expect to find it in the haynes manuel, that book is useless for auto tranny problems as it tells you to take it to the dealer. Good luck.
Old Aug 12, 2001 | 12:16 PM
Alvin's Avatar
Cool
Hi ChiefHighwater,
The actual name is a vacuum diaphragm (according to the rx7 work shop manual). The R&R procedure is on page 7B-16. If you don't have a manual (I got mine thru E-bay), the valve is on the left side of the tranny, you don't need to drop it to get to the modulator. You will need to take out some of the tranny fluid as you will get a little wet when you remove it. If you're already low on fluid, you have it made. You will have to jack up the car unless you are very very thin. Before you call mazdatrix, you might try calling a few auto parts places.
You might want to invest in a shop manual, while it may not be the best, it does have a lot of useful info on the auto tranny, with lots of t/s. Have a nice day
Alvin
Old Aug 18, 2001 | 12:33 AM
Alvin's Avatar
It's great to hear that your problem is solved. It cost me a little more, but that's what's great about this forum.
Have a nice day!!
alphawolff
Nov 17, 2015 05:57 PM
Alexanderific
Aug 21, 2015 07:44 AM
Wicked93gs
Aug 17, 2015 12:14 PM
