17x8 32 offset and 17x9 38 offset...for FC3S
Old Aug 11, 2001 | 12:58 AM
streetpower's Avatar
what is the biggest tire i can fit on my FC3S with a 17x8 32 offset and 17x9 38 offset......
also where can i buy center caps for ...racing sparcos ns II viper
Old Aug 12, 2001 | 11:25 AM
13BAce's Avatar
On a long vacation
Re: 17x8 32 offset and 17x9 38 offset...for FC3S
225/45/17 will fit up front. You should be able to get 245's in the rear. 255's MAY rub the trailing arms. I have 275/35/18 on 18x9 with a +30 mm offset in the rear.
Old Aug 13, 2001 | 03:35 PM
ARD T2's Avatar
I think the front will rub. My 37mm's rub very slightly. If rolling the fenders you should be fine. The rears should fit fine. I sell 35-38mm 17,9.5's all day long, w/o rubbing. therefore your 9" w/38 should fit beautifully. Should be able to dump it if you want.
See ya, Rishie
Old Aug 13, 2001 | 09:39 PM
so would...225/40 /17 for the front
and 275/40/ 17 in rear or 255/45/17?????
Old Aug 14, 2001 | 06:47 AM
13BAce's Avatar
On a long vacation
225's should be ok up front. I would go with 245's in the rear because if the 255's wind up rubbing the trailing arms you'll need spacers.
Old Aug 17, 2001 | 08:13 PM
Jerk_Racer's Avatar
Not all tires are created equal. Don't forget two different tires (different brands, models, or even speed ratings) side by side with the same aspect ratio can be different widths. Try to get the tire dimensions from the manufacturer when you find a tire brand/model that you want.
jerk_racer@hotmail.com
Old Aug 18, 2001 | 12:28 AM
BOOSTD 7's Avatar
Persona non grata
So 17x9.5's with a 38mm offset fit fine in the rear? Neato
Old Aug 19, 2001 | 02:04 PM
Trinity Rx7's Avatar
I test fitted some rims one my t2 and 17x8 with a offset of 38 fit great in the front. The back were 17x9 with a 38 offset, the rears had a 255 on them and they were close but not rubbing. My question is what offset would be needed to run a 275 in the back? Would the offset increase or decrease to put the wheel a little more out for wider tires to not rub the arm back there?
Old Aug 21, 2001 | 07:07 PM
ARD T2's Avatar
To bring a wheel closer to the fender, you want a lower offset. To push it in more you want a higher/more positive offset.
Good luck, Rishie
SULLY's little brother is running a 255/40 on 17,9.5 w/ 35 mm offset. No rubbing. It's been proven. Oh yeah, on NT555 nittos.
Old Aug 21, 2001 | 07:29 PM
So to run a 17x9 in the rear with a 275 I would need to get something like a offset of 35 or maybe even lower? I really want ot be able to run a 275 in the back, a 255 would be nice, but I really like the looks of the 275's. Thanks for the help. Also are you the guy that can get rims? If so I might have a question for you
Old Aug 21, 2001 | 07:38 PM
13BAce's Avatar
On a long vacation
I have 275's on 18x9 with a +30mm offset. I have about 1/2" clearance with the trailing arm. So +35mm should work, but it will be tight.
Old Aug 21, 2001 | 08:07 PM
Cool, thanks for the help
Old Aug 21, 2001 | 08:19 PM
Sully's Avatar
Yeah Trinity Rishie AKA ARD T2 is the man to talk too
Old Jul 27, 2010 | 01:24 AM
Zonafyd09's Avatar
Offset info
Hi ARD T2,
OK SO IM HEARING THAT YOUR THE OFFSET AND WHEEL GURU SO IMMA COME TO YOU...
I WANNA PUT SOME OFFSETS ON MY T2 BUT I DONT KNOW ALL THE DEMENSIONS AND STUFF LIKE THAT... I DONT WANT THE TIRES TO BE INSIDE THE FENDER BUT MAYBE AN INCH OUTSIDE OF THE FENDER...
WHAT WOULD 17X9.5 OFFSET 38MM IN THE FRONT AND 17X9 OFFSET 38MM IN THE REAR LOOK LIKE?
