diff bushes
Old Jan 10, 2003 | 10:34 AM
CTHIS RX7's Avatar
diff bushes
Well I need new diff bushes as the ones I have now are leaking fluid which can't be good. So the question is, do I get the standard Mazda ones again or get a custom set made up? anyone got any opinions or experiences with what I should do?
Old Jan 10, 2003 | 11:56 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
your diff bushings are leaking? what symptoms beyond that do you have? I replaced mine with stockers and they work fine its the other parts of the suspension that needs some stiffer bushings. To get to them you have to pull the axles and drop the diff. real PITA!!
let me know if you have q's.
-Ryker
Old Jan 10, 2003 | 01:59 PM
TailHappy's Avatar
Addicted to Track
Mazda Motorsports has solid bushings that are cheaper than the stockers, if I remember correctly. They're a little stronger, but they're not urethane, so they aren't too harsh either. I installed them on mine once I broke both the fluid-fill ones and have been happy with them so far.
You have to race your car (autocrossing counts) twice a year to qualify for them though.
www.mazdamotorsports.com
Old Jan 10, 2003 | 03:39 PM
es's Avatar
es
You don't have to pull the axles. Once the fuel filter & charcoal canister are out of the way unbolt the drive shaft, the 2 Diff mounting bolts & PPF then rotate the diff down so the nose is pointing the floor. Take an impact gun to the 4 bolts to get the diff mount off the diff...
I did a how to:
http://www.geocities.com/rx712psi/Diff.html
Old Jan 10, 2003 | 03:48 PM
Wargasm's Avatar
Weird Cat Man
es
Nicely done! I just happen to have my PPF, driveshaft, transmission, exhaust all off the car right now for some transmission work. I guess the only parts I need to take off are the cross brackets, fuel filter, canister, and the diff mounts themselves.
Maybe I'll do the diff mounts now rather than later after I put all that mess back in
Brian
Old Jan 10, 2003 | 04:06 PM
kempo's Avatar
pettit has new bush. that is harder than the stock and softer than the solid and will not transmit vibration and noise to the chassis. just got them a few months ago and thy work great.
Old Jan 11, 2003 | 11:44 AM
CTHIS RX7's Avatar
thanks for the help guys!
James Knox
Oct 5, 2015 07:56 AM
