Coil-overs killed my stock car jack?
Old Jan 8, 2003 | 11:01 PM
BLUE TII's Avatar
Rotary Motoring
I attempted to jack my '87 TII up for the 1st time since I put JIC coil-overs on it w/ the stock jack. I got that corner a couple of inches off the ground and the stock 2nd gen jack stripped out
I stepped back from the car and I see that only one tire is on the ground because of the stiff short stroke suspension. Ah, I think the stock jack was overloaded.
Has anyone else experienced this? What jack do you guys carry in your car? Thanks, Ian.
Old Jan 9, 2003 | 03:34 AM
ARD T2's Avatar
AAA. lol. No jack, no spare. No weight.
Sorry I couldn't help much bro.
Old Jan 9, 2003 | 03:40 AM
Makenzie71's Avatar
...94% correct.
where did you have the jack at? It's kinna hard to imagine you getting it into a perfect position to balence the car on one wheel. I've jacked both front wheels, both rear, both pass/driver wheels with the stock jack. Never had any problems. You could, now, get a steel jack from an S5, or go get a small 1 ton jack from autozone or something that will fit great in any one of the various holes in the car.
Old Jan 9, 2003 | 09:00 PM
BLUE TII's Avatar
Rotary Motoring
Stock recommended front corner jacking point! Yes, I was very surprised to see 1 wheel on the ground.
I think I will rebuild the stock jack w/ steel threaded portion and "nut" at inside pivot.
I was using the jack in the garage since the car was too low to fit my floor jack under a correct jacking point.
I will check out S5 jack, didn't know they were different.
Thank you, Ian.
Maybe I will get some "tender springs" so I can have some droop to the suspension w/ out having spring "slack".
Old Jan 10, 2003 | 08:28 AM
Samps's Avatar
I believe the jack that came in the verts was a little beefier due to the increased weight.
