Knock readings(help)
Old Jan 8, 2003 | 03:37 PM
Unhappy Knock readings(help)
Hello,does anyone know why my knock readings are suddenly a lot higher than normal.The only thing i can think of is the cold weather (-2 at present).Im from the UK and im using 99 oct fuel,the mods i have are power fc on stock map,downpipe,midpipe,catback,ind kit,1-1 fpr,fmic and ebs4 boost controller set up to 14psi and 2 extra secondary inj.Also what sort of power should i expect with these mods at the flywheel.Thanks in advance Roy.
Old Jan 8, 2003 | 04:14 PM
rynberg's Avatar
I believe the temp corrections on the PFC are not as accurate as they should be. You are also pushing a lot of mods for an untuned base map (!) You need to go to a dyno with a wideband A/F sensor and see what your A/F ratios are looking like. You might need to adjust the temp correction or add a bit more fuel in the cells you are getting knock in.
Old Jan 8, 2003 | 07:00 PM
MichRX7's Avatar
Re: Knock readings(help)
You had better get over into the PFC forum immediately before you pop that engine. Especially running the stock map @ 14psi with your mods.
https://www.rx7club.com/forum/forumd...?s=&forumid=47
rgordon1979
40
Mar 15, 2022 12:04 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
83revival
Sep 3, 2015 10:42 PM
