Do all cars do this??
Old Jan 8, 2003 | 02:37 PM
My friend was driven my car (i was riddin wit hime, of course) and we hit like 95mph on the interstate, and the car started to shake VIOLENTLY, like the front dash and windows going crazy. The ONLY thing i can think of is i need a front wheel alignment bad. could this cause this? or do most rexs do this aroun 90-100mph
Old Jan 8, 2003 | 02:44 PM
peejay's Avatar
Old [Sch|F]ool
Alignment has nothing to do with it. Alignment will never cause a shake or a vibration.
One or more of your tires is probably out of balance if not out of round. Due to the low-friction steering compnents, and the fact that it's a light car with small tiameter tires, 1st-gens are *very* sensitive to imbalance or out-of-round. I could feel the difference 1/4oz makes at 65mph. I could also feel out-of-round of less than 1/32". My shop manager thought I was nuts when I showed him the "defective" tire ("That's fine, you're just crazy...") but then I took him for a road test and he agreed, you could feel it!
But when everythings round and balanced, you should have no shakes at all. 124mph = smooth as glass.
Since it's that bad, you might also want to check for loose U-joints.
Old Jan 8, 2003 | 02:58 PM
clean85owner's Avatar
Nigga stole my bike!
Parts of my car start to fly off at that speed (seriously). The doors and windows shake horribly. I don't think it's tire pressure because my dad makes whoever is driving the car at the time to check the tire pressure once a week.
Old Jan 8, 2003 | 03:02 PM
peejay's Avatar
Old [Sch|F]ool
Tire pressure won't cause a shake or vibration either.
Shakes and vibrations come from two causes... something rotating is out of balance, or the tread surface of the tire is not round. That's it.
Old Jan 8, 2003 | 03:09 PM
82transam's Avatar
Never Follow
yep, balance those suckers and you should be fine.
Old Jan 8, 2003 | 06:36 PM
yeah if you have a 1st gen check the u joints of your driveline... the like to go out... cant be replaced either... have to replace the whole driveline...
Old Jan 8, 2003 | 07:20 PM
hornbm's Avatar
FD > FB > FC
if you have to replace the driveline, mazdatrix sells a replacement driveline with changable u-joints for about 100 bux less than the OEM unit.
Old Jan 8, 2003 | 09:08 PM
White84SE's Avatar
U sUx0rz @ THe IntaRwEB!
If you have an '81-'83, yes, you CAN replace the u-joints in the driveshaft. It's only the '84 and '85 that have a nonserviceable driveshaft...
--Danny
Old Jan 9, 2003 | 01:50 AM
Amagi82's Avatar
50+mpg, woo!
My last set of tires were balanced so bad that at 100mph you could see the top of the door window moving back and forth about 3 inches. It was downright frightening
Old Jan 9, 2003 | 02:29 AM
V8kilr's Avatar
dont forget bad u-joints and fix-a-flat in a tire
Old Jan 9, 2003 | 02:30 AM
V8kilr's Avatar
--Danny
dont give anyone the wrong idea they are changable, we had this discussion.
you have to remove the old ones and get the new greasable style that the snap rings mount on the inside instead of the outside, I have a shop that has them if anyone needs them.
sorry didnt mean to single you out, this also goes to I **** on hondas and hornbm
Old Jan 9, 2003 | 02:55 AM
RotorMotorDriver's Avatar
Seven Is Coming
Hmm...Anyone know the visual differences between the drivelines? Anyone have some pictures? When I built my car, I used one of two drivelines I had laying around. I dont know if it was an 83 or 84. If I can change the ones on my 83 driveline, Ill buy new U joints and use that one instead .
~T.J.
Old Jan 9, 2003 | 10:33 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
ok, how many times have you driven this "VIOLENTLY" shaking car at ludicrious speed? I suggest you stop until you get it fixed 1st off
2nd, I agree with these guys.. get your wheels balanced.
Old Jan 9, 2003 | 10:39 AM
pillage6's Avatar
Could be bent rim, that is my problem.
Starts wobbling at about 60mph and the wheels are perfectly balanced, but they said my wheel is bent.
I was curious how a wheel can be balanced and bent at the same time.
Old Jan 9, 2003 | 10:48 AM
mar3's Avatar
Administrator
I'm with peejay on this one....if the vibration and shaking is appearing at a certain speed, then it's almost certainly bad U-joints...
Old Jan 9, 2003 | 11:31 AM
lotsacars's Avatar
Could also be a shifted or broken cord in one of your tires (sounds like a front). I just replaced a set on my daily driver that had a broken cord in one of them. It kinda deforms the tire and wears it funny. It also only vibrated at certain speeds.
Old Jan 9, 2003 | 11:51 AM
--Danny
HI,
IS there a way to put a 1981 driveshaft in a 1985. I got one 1981 in good shape and my 1985 is shaking a little bit.
thanks
ve2cvx
Old Jan 9, 2003 | 01:49 PM
this is the FIRST time i've ever gone this fast, so its not a habit, ALSO, it only shakes in the front, not the back of the car, so if the u-joints where bad, wouldn't the whole car shake?
Old Jan 9, 2003 | 09:36 PM
RH-7's Avatar
I'm pretty sure that if I drove my 82 that fast it would blow up.
Old Jan 9, 2003 | 10:38 PM
brownmound's Avatar
Anytime baby!
My SE used to shake a bit ~80 mph. Four new tires solved the problem. The previous tires were old, very worn and surely out of balance.
Right on.
Old Jan 9, 2003 | 10:54 PM
Dang everyones having probs with their cars but yet mine stay smooth all the way to 140mph, one time it started shaking some at 90 so I got the wheels balanced and from then on its been fine
Old Jan 9, 2003 | 11:08 PM
faye x7's Avatar
brilliantly stupid
I've had my 82 only just above 100mph and my car was smooth as silk.
But anyway..yeah...everybody else has pretty much given you the choices as to what the problem is, no sense in repeating it myself. heh
Old Jan 10, 2003 | 11:23 AM
DBOGGSRX7's Avatar
Damnedknowitall
I have read here more than once that you cannot replace the u-joints on the earlier (I have an 81) first gens. Last year I had a viberation that seemed to be coming from the transmission / rear of the car. It turned out to be the u-joints on the drive shaft (try shaking it up and down, if it moves, they're shot). Replaceing the u-joints cost $15.00 per u-joint and took about an hour.
Dennis
Old Jan 10, 2003 | 11:29 AM
DBOGGSRX7's Avatar
Damnedknowitall
Oh yeah, before "spirited" driving of that sort, there are alot of things that need to be checked on your car. Tire unbalance can cause ver ugly problems, all of which will cause you to loose control of the car. others you may want to look into...
Ball joints, tie rod ends (or any other play in the steering), drive belt conditions, Brakes!!!!, Alignment is kind-of-important due to tire temperature at high speeds.. I am sure there are others. I spent a month looking over my car and fixing **** before I drove at "those" sort of speeds.
my 2 ¢
Dennis
Old Jan 10, 2003 | 11:36 AM
1st7heaven's Avatar
Back in the day when my car was on the street, I had bad window and door seals. The air preasures(inside the car) at those speeds caused the car to vibrate inside......like you said, the whole car would shake!!!
