Coolant at start up
Old Jan 7, 2003 | 10:52 PM
93TTRX7's Avatar
Coolant at start up
Here's the deal...I started my car up for the first time in 2 days after the battery died. So i went for a little drive (non boosting) and when I came back I noticed there were a couple of drops of coolant on the ground. There were maybe 4 or 5 drops total. I don't think this had ever happened before, but for the past few weeks as I was driving I could also smell coolant once I turned my fans on. I have an aftermarket water temperature gauge and have never overheated (gone over 110 c).
Now my question to you is is this a sign that the coolant seals are shot or does this mean I have a nice little leak at either my (radiator hose, radiator ends, or overflow->ast line)?
I'm not familiar with a blown coolant seal so I don't really know how much coolant is supposed to puke out of the tank if the seals are bad. There wasn't any smoke and I didn't even get the buzzer. I was gonna take it to Rotary Power in Gardena anyway tomorrow...well good thing I had already made the appointment.
Old Jan 7, 2003 | 10:57 PM
Mahjik's Avatar
Mr. Links
Usually, with a coolant seal leak the coolant gets into the combustion chamber and gets burn out your exhaust (hence the whiteish/blueish coolant smelling smoke coming out of the exhaust).
If you are seeing it hit the ground, it's very doubtful it's a coolant seal.
You might start by checking the lines that run to/from the AST. Those tend to fail quite often. Mine did and it only leaked when the hose was warm. When the hose was cold, it sealed itself. lol
rx7shirley
Sep 2, 2015 02:11 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
