very important: what would be the best things to do for a service
Old Jan 6, 2003 | 05:34 AM
timmya2's Avatar
Exclamation very important: what would be the best things to do for a service
im getting my rex serviced tomorrow so i need your help guys
i was thinking along the lines of..
replace oil - none synthetic
spark plugs
spark plug wires
distributor cap
distributor rotor
air filter (k&N)
Fuel Filter
and flush the coolant
pls tell me wat else i should add
do u think replacing the distributor cap is important or not that important?
wat would be the top 3 - 4 things i should definately do which is the most important out of all of them..
THANX GUYS I LOVE YOU ALL
Old Jan 6, 2003 | 06:07 AM
S2-13BT's Avatar
Oil and oil filter
Plugs
Fuel filter
Coolant
Clean the filter if you already have a K&N
Check the Dizzy cap and rotor button and replace if necessary. Same with the plugs and wires I suppose.
Maybe just do a check of things like tyres, suspension bushings, worn shocks and sagging springs.
Can't think of anything else right now.
Old Jan 6, 2003 | 06:18 AM
timmya2's Avatar
thanx heaps man..
any others who think that the top 3-4 things i should definately change/service is different from S2-13bTs answer?
Old Jan 6, 2003 | 11:40 AM
Manntis's Avatar
add to cart
not much, but be sure the filter has the valve Mazda rotary filters need - they get put upside down in relation to other filters, and the oil could drain out when parked without the valve - leading to oil starvation on startup
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
Frisky Arab
Sep 4, 2015 06:17 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
