rats nest/air pump on 85 se
Old Jan 5, 2003 | 06:31 PM
seein7s's Avatar
i have looked everywhere for info on the removal of the ratsnest and the airpump for a 85 se 13b. any info would be great. thanks
Old Jan 6, 2003 | 02:08 AM
Rotary13B1's Avatar
May I ask why you are removing it in the first place?? Air pump I understand if you are putting in a cone filter or exhaust, but why the rats nest??
If you want to remove the air pump, just unloosen the 14mm nuts and bolts, remove belt and pump... viola! The nest will require the removal of the dynamic chamber which are comprised of 10 and 12mm nuts, the throttle body coolant hoses... hope that answers your question.
AL
Old Jan 6, 2003 | 02:10 AM
faye x7's Avatar
brilliantly stupid
If you use the search feature you'll come across a very good write up. DUDE!
Old Jan 6, 2003 | 09:09 AM
pratch's Avatar
Mazspeed.com
Or if you just wait long enough - I'll come across your post and pimp the write-up.
http://maz_tutorials.totalimmage.com
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
