? about negative wire on battery
Old Jan 4, 2003 | 03:07 PM
silverflash2's Avatar
My rx7 has been giving me a hard time starting (cold start and hot). I have a fairly new battery.and it seems that my negative cable on the battery is bad.It seems to be broken.If i wiggle it or bend it a certian way it starts right up.My question is how difficult is it to replace the whole negative wire. I don't have alot of tools,and i'm not sure how far back the negative battery cable goes.
Old Jan 4, 2003 | 03:52 PM
GsrSol's Avatar
Z06 powered FD
I think it goes down to the bottom of the housings. If that's the one I'm thiking about then it's fairly easly to replace. Measure it then go to the local parts store.
Add an extra one while you're at it to another place.
Oh yea, is it slow turning over or does it act like a dead battery?
Old Jan 4, 2003 | 04:55 PM
skunks's Avatar
I'm a CF and poop smith
go to your local parts store and find a new terminal, one which has a coupler type of attachment on it (so that you can just strip back the wire and it clamps down on it). you can also put more ground strips. then just cut the current neg battery terminal and replace it.
Good luck
rgordon1979
40
Mar 15, 2022 12:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
