OMP help!!!
Old Jan 2, 2003 | 08:08 PM
mmonaco's Avatar
Part out my Car
OMP help!!!
Ok if you took off the OMP and you turned your car on, how much oil would you lose? Is alot of presure coming out of those holes?? Dose the presure change as the Rpms change, ie more presure at higher RPMS? TIA
Marc
Old Jan 2, 2003 | 08:34 PM
turbojeff's Avatar
Do it right, do it once
You'd lose all the oil a matter of minutes. It is fed by the oil pump, oil pressure does vary by rpms but there is a oil pressure regulator.
Jeff
Old Jan 2, 2003 | 09:08 PM
mmonaco's Avatar
Part out my Car
Hey so if i disconted the OPR then ill have no oil presure right, the OPR only controls the OMP right?
Old Jan 2, 2003 | 09:09 PM
mmonaco's Avatar
Part out my Car
If you premix you dont need the OPR and OMP right?
Old Jan 2, 2003 | 10:07 PM
paw140's Avatar
I think what jeff means by the oil pressure regulator is a valve inside the oil pump body. All oil pumps have them to regulate oil pressure throughout the engine. You can't really remove it.
If you premix you don't need the OMP. But you can't do this if you have the stock ECU.
Old Jan 2, 2003 | 10:10 PM
paw140's Avatar
Let me elaborate a bit. If the stock ECU detects a problem with the OMP, it will put your car into a mode in which it is barely drivable. Some people call it limp mode. Its just enough that you can drive it home, but thats about it.
So you can't just remove the OMP and put a block off plate on and expect the car to run ok if you have a stock ECU.
What kind of problem are you having?
Old Jan 2, 2003 | 10:32 PM
turbojeff's Avatar
What I thought you were asking, "if I start up the car how much oil will come out of the OMP holes". The answer is a WHOLE LOT OF OIL.
Now if your asking if you can block it off and just run pre-mix. Well like paw140 said, yes you can. But you need to have something other than a stock ECU.
The OPR is needed on all engines. The oil pressure would go absolutely through the roof if the engine didn't have one.
What are your plans?
Jeff
Old Jan 2, 2003 | 10:34 PM
mmonaco's Avatar
Part out my Car
Well im going haltech, and it dosent control the OMP! should have said that! Im thinking that there is gonna be alot of presure pushing against that plate!! Im just thinking i dont want it to leak oil every where!!
Marc
Old Jan 2, 2003 | 11:22 PM
mmonaco's Avatar
Part out my Car
IM saying i just dont want a huge leak!! From the block off plate!!
Marc
Old Jan 3, 2003 | 07:28 AM
rxrotary2_7's Avatar
i have haltech, no OMP, blocked of by a BOP. and no problems. i used *the right stuff* to put a seal around the edge of the BOP. the right stuff is amazing. i love that ****! it comes in a black tube, expensive, but worth every penny. it seals wet or dry.
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
