body parts
Old Jan 2, 2003 | 03:37 PM
nipper's Avatar
body parts
Does anybody know where I can find rear quarter panels for a first gen. rx7. Steel or fiberglass, it doesn't matter
Old Jan 2, 2003 | 10:59 PM
wwilliam54's Avatar
it WILL run
atlantarx7.com
mazadatrix.com
Old Jan 2, 2003 | 11:15 PM
Keaponlaffen's Avatar
The rear q-panels aren't replaceable on an RX-7, as the car is a unibody design... the whole rear end is one piece all welded together, so unless you're willing to find a donor vehicle, chop the rear end off of it, chop the rear end off of your car, and weld the new/used pieces on, then fill, sand, prime, and paint it, I would suggest looking for a new car if it's damaged enough to need replacing.
Jeff
Old Jan 2, 2003 | 11:33 PM
wwilliam54's Avatar
it WILL run
oh yeah!!!!
woops
Old Jan 2, 2003 | 11:35 PM
No problem You'll learn
Jeff
Old Jan 2, 2003 | 11:37 PM
Manntis's Avatar
add to cart
You can buy separate panels, intended for body repair, that weld in after the old ones are cut out, without having to buy a donor vehicle. If Mazdatrix doesn't have 'em in stock try asking your local auto body shop.
Old Jan 2, 2003 | 11:40 PM
Yeah, good point, I've just never actually seen replacement rear q-panels?
Old Jan 2, 2003 | 11:48 PM
Manntis's Avatar
add to cart
When I restored my Z-car they had replacement anything - pretty much any stamping or portion of stamping is available, if you know where to look
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
82streetracer
Aug 23, 2015 09:28 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
