Rules for battery relocation?
Old Jan 2, 2003 | 07:31 AM
Samps's Avatar
I have relocated my battery into the trunk of my S5 vert. This summer I plan to auto-x and was wondering how the rules go with relocated batteries. Right now it is in the stock plastic box that used to be under the hood. I used the stock brace that goes across the top of the battery and drilled two holes in the trunk for the J-bolts. Right now the battery is secure enough that I can shake the whole car by shaking the battery. It will not move at all. But I have read that they are pretty strict about battery location and how well it is secured. I just don't want to drive up to an auto-x and get rejected for something I can fix easily now.
Old Jan 2, 2003 | 07:33 AM
Samps's Avatar
Here is a pic of how it is now.
Old Jan 2, 2003 | 08:12 AM
Rx7carl's Avatar
Airflow is my life
IIRC the tray its mounted to MUST be metal, so your bolts thru the structure should be ok. Security is what the techs focus on.
Old Jan 2, 2003 | 08:42 AM
redrotorR1's Avatar
LS6 Convert
Should be fine. Techs will be more concerned about your safety; so as long as the battery is secure in its placement, you shouldn't have any problems. FYI, Street Prepared and beyond written regulations for battery relocation:
Relocation of the battery or batteries is permitted but not into the passenger compartment. If the battery is relocated and the original battery tray can be removed by simply unbolting it, the tray may be removed, or relocated with the battery. Holes may be drilled for mounting or passage of cables. Longer cables may be substituted to permit relocation. The number of battery or batteries may not be changed from stock. The area behind the rearmost seat is not considered to be within the passenger compartment.
Old Jan 2, 2003 | 01:43 PM
Samps's Avatar
Thanks guys! I was concerned after reading that drag racers need to have their J-bolts welded shut if the battery is relocated into the trunk. I also added the inline fuse for some bonus protection.
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
choddaboy
Sep 26, 2015 06:35 PM
Devon Murray
Sep 25, 2015 09:41 AM
