Quick motor mount removal question...
Old Jan 1, 2003 | 02:17 PM
FD Seeker's Avatar
Rotary Optimist
Exclamation Quick motor mount removal question...
I've read that removing the nuts from the bottom of both motor mounts would allow you to jack up the engine.
I've removed these nuts but jacking up the engine jacks up the whole car!
Is there something else to unbolt?
Do I just need to wiggle the car until the motor mount studs slip through the subframe?
What gives?
Thanks in advance.
Old Jan 1, 2003 | 02:24 PM
xstacy7's Avatar
I love when things work
Is it still attached to the tranny?
Old Jan 1, 2003 | 03:41 PM
FD Seeker's Avatar
Rotary Optimist
If you mean the engine and transmission - yes, they are attached. I've placed the jack under the transmission to raise the engine - as recommended in several other threads.
If you mean something else, please elaborate.
Old Jan 1, 2003 | 03:57 PM
nocab72's Avatar
03 Cobra Killer
It doesn't need to move very far... maybe an inch to an inch and a half to get tools onto the bolts for the motor mounts that go into the bottom of the block and work the mounts themselves out after unbolting.
K
Old Jan 1, 2003 | 04:49 PM
FD Seeker's Avatar
Rotary Optimist
Lightbulb Figured it out
Well, the engine started moving independent of the rest of the car after I jacked it up some more. Apparently I just wasn't jacking enough (being conservative).
Now that I have the clearance I'm able to remove the mounts fairly easily.
Old Jan 1, 2003 | 05:58 PM
mmonaco's Avatar
Part out my Car
Taken the croos memeber isnt that hard withor, but looks like you got it figured out!!
Marc
Old Jan 1, 2003 | 11:14 PM
TomsRX7's Avatar
Glad you figured it out. FDSeeker, I like your Avatar; that's pretty tight!!!
-Tom
