cd player install problems
Old Dec 30, 2002 | 11:39 PM
CaR 13's Avatar
Arrow cd player install problems
this is my first install for any cd player so if i can get the answers in terms i could understand.
i have my car rewired from the cd player to the 4 speakers in my car, but the 2 wires that run the cd player. one goes to the always on connection and the other goes to on only when the car is turned on conection. which wires do i connect those two wires to.
which color, and where there located would be very helpful.
thanks
i hope someone can make sence out what i wrote.
CaR 13's Avatar
i need to fin out which wires i use to get the cd player running
Old Dec 31, 2002 | 12:04 AM
S2-13BT's Avatar
To be given advice on which wires top use by colour, you may want to mention what year of car you have (I'll assume it's a 7 ).
Otherwise, get yourself a multimeter or voltage tester light thingy, and start poking wires with the ignition on and off until you find something suitable.
Good luck.
Old Dec 31, 2002 | 07:05 AM
jeff48's Avatar
Rotorally Challenged
Buy yourself a couple of fuse panel expanders at AutoZone. These things are fuse like blocks that have space for two fuses and a wire sticking out of them. At the base of the block there are the blades just like you find on a stock fuse. Pull a fuse that is marked to power a constantly powered accessory. You place a new fuse in the top slot and the original fuse from the fuse panel then goes in the bottom. Crimp a new length of wire to the wire connector coming from the expander. Press the expander into the space you just pulled the fuse from. You now have a constant +12 that is individually fused. Do the same with a switched +12 and you are now ready to attach the CD player
Hope this helps
Old Dec 31, 2002 | 11:07 AM
CaR 13's Avatar
I HAVE A 88 SE RX7
Old Dec 31, 2002 | 05:12 PM
jeff48's Avatar
Originally posted by CaR 13
I HAVE A 88 SE RX7
SO WHAT???!!
IT'S A GENERIC INSTALL (2 syllable translation: works on ANY car)
Good god man, you asked a question AND copped an attitude...get a life
Old Jan 1, 2003 | 12:09 AM
CaR 13's Avatar
jeff48
what r u talkin about?
i answerd a question S2-13BT asked me you probly just read what i wrote wrong.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
