Haltech Wiring Questions......
Old Dec 28, 2002 | 09:47 PM
streetpower's Avatar
OKAY I HAVE A FLYING LEAD HARNESS AND STARTED TO WIRE UP MY 93'FD TODAY...COUPLE QUESTIONS ON THE WIRING
1) INJECTOR WIRING MY INJ HAVE 2 WIRES I WIRED THE LEADS FROM THE HALTECH HARNESS TO EACH INJ NOW I HAVE A BLACK LEAD ON EACH INJECTOR NOT WIRED AND DIG OUT 1 + 2 AND 13.8 RED WIRE NOT WIRED...WHAT SHOULD I DO WITH THESE WIRES????
2) DO I NEED TO HOOK UP MY ROAD SPEED AND IF SO HOW TO
3) ON THE TRIGGER INPUT (J16) WHAT DO I DO WITH THE THE GROUND WIRE AND THE 13.8VDC
4)ON MY IGNTION OUTPUT THE AUXILIARY OUTPUT, GROUND AND INJ 1 IS NOT WIRED WHAT DO I DO WITH THESE?
THANKS
SEAN
Old Dec 29, 2002 | 09:09 AM
rxrotary2_7's Avatar
1. they all share the red wire as a common wire. (refer back to your stock harness. they all conect together.)
lt blue is inj1
blue/red is inj 2 (1&2 are your primary injectors)
green/red is inj 3
pink is inj4 (3 & 4 are secondary inj)
2. yes. there is a grey and yellow wire (i belive) from haltech for this. it gets connected to a green/red wire. i forget the pin conection from stock harness.
3. you dont have to hook them up to anything. just cut them off.
4. picture the igniter on its side with the wires facing to the right. the one unused wire spot at the bottom. top wire being pin A
A= dig out 2 (blue)
B= neg side of trailing 1 (will be your front rotor)
C= dig out 1 (white and black)
D= connect this to a switched 12v source.
E= neg on trailing 2 (rear rotor)
F= haltech's ign out (its the lt green wire)
G= to the negative of the leading pack
H= gets no connection
in the setup page set it like this.
output type: constant charge
output edge: falling
time: 3ms
type: rotary
spark mode: direct fire
hope that helps a little.
BTW...the caps lock key on your key board is above the shift key on the left side...next to the A key and below the Tab key.
Old Dec 29, 2002 | 10:57 AM
SORRY ABOUT CAPS LOCK....BUT MY DAUGHTER HAD AN ACCIDENT WITH KEYBOARD AND JUICE....
ANYWAYS RELATING TO THE IGNITER WIRE UP SO ALL I NEED IS THE 3 WIRES TO BY HOOKED UP ..BLUE, WHITE AND BLACK AND LT GREEN.......THE OTHER 3 WIRES FROM THE E6K HARNESS DOES NOT NEED TO BE HOOKED UP..GRN/BLK, BLK AND LIGHT BLUE.....IS THAT CORRECT??
THANKS
SEAN
Old Dec 29, 2002 | 03:04 PM
follow my directions for #4 and it will work.
remember the flying lead or e6k for that matter was not designed for ONE car so not every wire HAS to be used on your application.
Old Aug 16, 2008 | 04:15 PM
Kahren's Avatar
i am not a girl
you got that backwards, the dig out 2 is for rear rotor and dig out 1 is for front
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
