Battery relocation???
Old Dec 22, 2002 | 09:48 PM
ioTus's Avatar
'84 5-letter
What do i need to do to put a new battery (to replace the old one), in the passenger side storage bin?
Old Dec 22, 2002 | 10:01 PM
Project84's Avatar
Open up! Search Warrant!
Go here
and then here
The second one is a write up from a guy on this forum who put a link to it in the first link ^ up there.
Old Dec 22, 2002 | 10:10 PM
ioTus's Avatar
'84 5-letter
If i get one of those red top gel cell or whatever they're called, do i need a battery box?
Old Dec 22, 2002 | 10:34 PM
Gizmo's Avatar
Universal Genius
http://www.rx7.voodoobox.net/howto/racecar/racecar.html
scroll down a bit
Old Dec 22, 2002 | 11:28 PM
Directfreak's Avatar
I am a Jeeper Now.
With a sealed Gel battery, you don't. However, I could not fit a battery box in mine, with the bin sections in place.
scroll down a bit
Notice the bins are completely removed.
Old Dec 22, 2002 | 11:30 PM
Manntis's Avatar
add to cart
still, nice craftsmanship on that box...
Old Dec 22, 2002 | 11:33 PM
EL PAALO's Avatar
and super nice job on sound deadening removal
Old Dec 22, 2002 | 11:36 PM
I am a Jeeper Now.
You like that? I can get you one for $500. Or, you can just buy it from Summit Racing for $89.
Old Dec 22, 2002 | 11:38 PM
I am a Jeeper Now.
Dry-Ice and a blade are your friends.
Old Dec 22, 2002 | 11:40 PM
onepointone's Avatar
i say what i want
is that in your car? how exactly is it mounted? ive been debating taking out the storage bins or not (i know another thread) but worried about structural support. not trying to take this off topic. bu
Old Dec 23, 2002 | 12:30 AM
I am a Jeeper Now.
No, those pics are of another car with the battery mounted in the box. I guess after re-reading the thread I could see the confusion into thinking it's mine.
I have a yelloe top optima in my passenger bin, properly bolted down, but no battery box (both don't fit.)
EDIT:
Actually, it would fit, if I removed the entire bin areas, put the battery and box in, and then built then bin area aorund them again. This was not an option to me at the time, although it might have to be if the rules change again at the racetrack.
Old Dec 23, 2002 | 02:13 AM
ioTus's Avatar
'84 5-letter
So how about i do this: keep the top of the passenger bin in there, but take the bottom bin carpeting out. Do a battery tie down to the base there, and run the red top battery..
Would that work? What ammount of wiring would i need to do, just extend the cables from the engine back to the battery?
Old Dec 23, 2002 | 03:42 PM
ioTus's Avatar
'84 5-letter
Would i need anythign else for that??
Old Dec 23, 2002 | 04:11 PM
RotorMotorDriver's Avatar
Seven Is Coming
Anywhere else "common" to put the battery rather than those bins? Mine are kinda taken up already...I was trying to justify putting in the back hatch area, but that means longer cables...
~T.J.
Old Dec 23, 2002 | 04:57 PM
i say what i want
i know its a different gen, but my dad put his battery all the way in the back because he has the rear seats (second gen) it wasnt too bad, he made the box himself and used some VERY thick wires. ill take some pictures if yall are interested. he was trying to get some weight out of the front of the car
Old Dec 23, 2002 | 04:58 PM
ioTus's Avatar
'84 5-letter
Yeah, i'm doing that, plus intercooler piping. Plust clean the engine bay up.
Old Dec 23, 2002 | 05:49 PM
Pedestrian X's Avatar
SpAz!
the longer the wires the larger gaueg you msut use.. or is it smaller gauge.. well uhhh ya know lower guage # uhhh .. well just use fattyier wires hte longer it is.
Old Dec 23, 2002 | 06:00 PM
i say what i want
my dad used 4g aircraft wire on his
Old Dec 23, 2002 | 08:08 PM
85RX7GS's Avatar
Now that is good stuff
Old Dec 24, 2002 | 03:15 AM
ioTus's Avatar
'84 5-letter
I still dont know how to do it.....
Old Dec 24, 2002 | 06:29 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Remember to fuse that big thick lead going to the battery. Or else you will have a nice toasty warm fire if the wire touches metal running through the car.
Old Dec 24, 2002 | 06:44 PM
MIKE-P-28's Avatar
It's not hard at all.
Just pull the starter (+) wire and the (-) that goes to the strut tower and then it winds down to the bolt holding the starter. Rip those wires out off the car... Now disconnect the wire at the (+) on the alternator (tape up the old wire and wire tie it out of the way somewhere, or cut it off and tape/ which ever you prefer), run a piece of 6 awg from the alt (+) to the screw below the 3 position fuse block on the drivers strut tower. Theres a single phillips head screw there... At that same point run a piece of 6 awg wire to the place the battery is going to be, IE drivers storage compartment... Now reground the engine block to the chassis of the car. I used the bolt holding the alternator bracket to the engine, and then to the strut tower.. I used 4 awg for this.
Now you will have to run a new (+) wire to the starter, i used 4 awg for this, I wrapped the wire in 3/4" heater hose / you cant fuse this wire cause of the high current draw of the starter when it cranks, and the wire will catch on fire if it rubs and shorts against metal. So be VERY careful how you run it...BTW: I recommend drivers storage compartment for the battery, you have to run less wire and it makes it easier to get to the starter.
Now at the storage compartment, you will have 2 wires, a 4 awg red for the starter and a 6 awg red for the car. Put a 100A circuit breaker on the 6 awg wire... Connect those 2 leads to the batterys positive... Now all you have to do is run a 4 awg black ground from the battery to the frame of the car, I drilled a hole in the crossmember, and used a grade 8 nut/bolt combo, and a star washer to ground it... Of course I used all the proper ring terminal etc. I used to work in car stereo, and nothing beats accidently taking htem from work OOOOPS
Voila you are done...
Old Dec 24, 2002 | 06:56 PM
MIKE-P-28's Avatar
OMG alex you removed the sound deading Really, I thought you were making a cadillac ride with some muscle lol
Old Dec 25, 2002 | 12:05 AM
I am a Jeeper Now.
No, mine is still there. I even going to add some dynamat in the future.
I just know an effective way to remove that crap.
Old Dec 25, 2002 | 10:24 AM
MIKE-P-28's Avatar
I figured, i was like in 'shock'
I will go back to singing all I want for x-mas is my mode 1 mariah wide body kit. Well we all know the answer to that, if they dont have it here by the jan 6th. Im calling them back and it wont be pleasant...Im a little upset about being lied to about not charging me for it till it shipped...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
RuffRx7
Oct 1, 2015 03:08 AM
choddaboy
Sep 26, 2015 06:35 PM
