carburators
Old Dec 24, 2002 | 10:52 PM
nucentz's Avatar
carburators
which carburator is worth the money? or should i just get the weber manifold & racing beat exhaust system. plus would i have to upgrade the fuel pump on these mods?
Old Dec 24, 2002 | 11:22 PM
specRX7_22's Avatar
i run the Yaw carb.... Carter big *** fuel pump with a holley regulator. that setup seems to work just fine for me. i highly recommend Yaw products.
--eric
Old Dec 24, 2002 | 11:24 PM
diabolical1's Avatar
Re: carburators
it all depends on what you seek. my advice would be start with the exhaust, then figure out where you want to go from there ...
Old Dec 24, 2002 | 11:36 PM
nucentz's Avatar
well im looking for a lil more juice from this 12A motor. i like the power now. but i wanna upgrade the ignition & all to it. however, this engine has over 150k miles which is the first i have seen. but this is also my first rotary engine car. maybe if i could get at least 120-150 hp ill be fine
Old Dec 24, 2002 | 11:45 PM
well im looking for a lil more juice from this 12A motor. ... maybe if i could get at least 120-150 hp ill be fine
well, the right exhaust system will give you the lion's share of your goal. RB all the way! upgrade your fuel system and make a few mods to the Nikki and i'm sure you can close in on 140 HP ... i know you can exceed 140, but that would require more elaborate working and tuning of the Nikki. as far as ignition goes ... leave it for last, and don't do too much unless you're planning to go for a LOT more power. as far as i'm concerned, as long as everything is working well, don't replace anything (coils, etc) unless it dies. just get some decent plug wires, advance your timing a couple degrees, and make sure you always have a good cap and rotor - you should be straight.
Old Dec 25, 2002 | 12:00 AM
nucentz's Avatar
thanks for the help man. i was looking at RB a minute ago & checking out their stuff. seems to be top quality stuff.
Old Dec 25, 2002 | 12:32 AM
is the stock carb on the rx7 a nikki?
Old Dec 25, 2002 | 12:37 AM
damn hippies
yes
Old Dec 25, 2002 | 08:51 AM
PaulFitzwarryne's Avatar
Apprentice Guru
With a modified Nikki carb, a good header and K&N air filter my 12a was dynoed at 128 rwhp which is about 150 at the flywheel. At this level of output the stock fuel pump copes as long as the fuel filter is not clogged.
Until the header/exhaust system is upgraded, any carb modification is a waste of money.
Old Dec 25, 2002 | 10:07 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
--eric
the qulaity of work is good, the performance per dollar is excellent, his ability to meet demand, and answer email is ZERO. Thats why I didnt go with his products, im still waiting for a reply from 2 emails , and that was 2 years ago! Ill PASS on that ****!
Old Dec 25, 2002 | 10:32 AM
specRX7_22's Avatar
Mike,
your exactly right.... he is so NOT customer oriented. if he wants business, hes gotta start caring a little more.
still like his work tho!
--eric
Old Dec 25, 2002 | 12:21 PM
nucentz's Avatar
so should i just do the RB header & exhaust first & drop in a K&N? how good is that nikki carb too? i wanna clean it out but i dont wanna kill it. someone told me to spray the gunk cleaner in it
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I'll let you in on a little secret, a modified RX2 carb works fantastic, and can be set up for 13B as well. I've already said too much... -WG
Old Dec 25, 2002 | 12:32 PM
nucentz's Avatar
RX2?
Old Dec 25, 2002 | 02:03 PM
RotorMotorDriver's Avatar
Seven Is Coming
Yes, the RX-2. As in before the RX-3 or RX-7 .
~T.J.
Old Dec 25, 2002 | 03:19 PM
MIKE-P-28's Avatar
rx2 would be rotary export 2nd attempt Old car.. Good luck finding one in a workable condition.. Id vote for doing an exhaust first and then worry about the carb... You can only take gas in as fast as you can get it out. First things first...
Old Dec 25, 2002 | 04:49 PM
Apprentice Guru
You already have the right advice. Fix the header exhaust system first and drop in the K&N flter and clean the existing carb without stripping it down.
Paul Yaw knows what he is doing and wll build you a 100% carb. But many rotary tuners can produce a similar result by modifying your existing Nikki carb. It will save you much time and money getting it done locally!
The critical point is the mileage on your engine. You are right in not seeking more than 140bhp- that will still give you a 1/4 time in the 15s. More power equals more wear and stress. The header/exhaust mods will get you 120-125 hp and modifications to your carb costing around the $200 mark will get the rest. Read some of the threads on the carb mods, Sterling had some good information.
Old Dec 25, 2002 | 04:55 PM
Hyper4mance2k's Avatar
The Shadetree Project
what modifications did you have done to your carb to get that much out of it??
Old Dec 25, 2002 | 05:54 PM
nucentz's Avatar
yeah im trying to learn on this car as much as i can. i know the rotary can gain alot of power with little amounts of money. so i may just do the header & clean out the existing carb to see if that will help with the air flow. another thing i saw was someone mentioning k&n. i checked out some guys site & he made a custom cai for his 7. so i may do that.
Old Dec 25, 2002 | 07:00 PM
Rx7carl's Avatar
Airflow is my life
WG, you talkin about the Hitatchi? WHere am I gonna find one dammit!
Old Dec 25, 2002 | 09:27 PM
79+80_rx-7's Avatar
I know where one is, i also know where, a complete rx2 sits.... waiting to be crushed
almost fully loaded
its sad, I want it, but I need to sell my 84 first.......
peace
Old Dec 26, 2002 | 12:14 PM
Wankelguy's Avatar
I have a bunch of Hitachis.
Old Dec 26, 2002 | 03:12 PM
Rx7carl's Avatar
Airflow is my life
I dont have any.
Old Dec 26, 2002 | 03:23 PM
Wankelguy's Avatar
They all need rebuilding anyway...
Old Dec 26, 2002 | 11:12 PM
82transam's Avatar
Never Follow
I got a question: when you guys all talk about modded nikki's what are you talking about? simple re-jetting? or are you guys doing more involved stuff?
