Power FC PFC with no airpump?
Old Dec 24, 2002 | 11:09 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
hi guys i took off my airpump with the greddy pulley kit and now the car has lumpy idle and runs really rich. I was told I need a pfc to remove fuel at idle. Question is, how do you go about doing this? I can do this with the commander correct? Or will I have to have a good rotary tuner do it for me? Thanks for the help.
Old Jan 6, 2003 | 02:06 AM
RX7 RAGE's Avatar
Top Answer: 1
anyone?
Old Jan 6, 2003 | 04:15 PM
redbase's Avatar
My airpump has been removed, but I don't have a lumpy idle.
Anyway, with the commander you can take out fuel by doing 1)a water temp correction 2)rpm correction by decreasing injector % per rpm.
I did this during the summer to help control the fuel smell at idle. I put everything back to normal this winter cause I don't want to run lean at anytime!
Old Jan 6, 2003 | 04:21 PM
cewrx7r1's Avatar
Eye In The Sky
Also with the PFC, you turn the O2 idle control off, and you can directly adjust the fuel in the INJ cells.
Old Jan 7, 2003 | 12:31 AM
RX7 RAGE's Avatar
Top Answer: 1
thanks
Old Jan 7, 2003 | 10:31 AM
Badog's Avatar
Think about it. What does the O2 pump do at idle? Pump air in. Disconnect it, you have less air or potentially an overly "rich" condition. You'll need to take some fuel out at the idle cells.
Also, if you keep the O2 sensor active (mine is) force the PFC to relearn. Disconnect the battery for about 15 minutes and pump the brake a few times, then re-connect the battery and start 'er up. Let 'er idle for about 20 minutes. Fiddle with the fuel for the idle cells in question (use map watch to find out what those cells are).
Einheri
Oct 7, 2015 12:23 PM
Turblown
Sep 30, 2015 05:58 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
