Sponsored by: CARiD
Transmission Removal
Old Dec 23, 2002 | 05:31 PM
10TH_ANNIV_T2's Avatar
Well, I'm trying to get my tranny out (88T2 see below), pretty much have everything unbolted and disconnected. I can get the tranny to slide back about 1/2", then I hit the edge of the hole where the shift lever goes through.
So I searched here, found a post that suggested loosening the motor mounts a bit, allowing the whole assembly to tilt. Great!, I got almost to 1", but just could not get them separated. The engine is in the car, and it's on stands, so I have about 15" to work with underneath. I do have the FSM, and double, and triple checked, everything is disconnected. Even with a rented tranny jack, just couldn't do it.
As I was gently wrestling it, there was a sound that I'd describe as rubber on metal maybe, but I couldn't tell where exactly the sound was coming from-- I have to believe all that's left is sliding the tranny off the input shaft, but the heck if I can do it myself.
Anyone have any suggestions on what the holdup might be?
Thanks,
Greg O.
Old Dec 23, 2002 | 06:10 PM
Wargasm's Avatar
Weird Cat Man
I find that the transmissions come out (and go in much easier) if you put a small jack (the spare tire jack will do in a pinch) with a small piece of wood under the front edge of the oil pan and apply a little force there to tilt the engine. This helps clear the shifter area. Be careful not to mess up your oil pan; be careful!
Brian
Old Dec 24, 2002 | 07:38 AM
Thanks Brian.
I did get clear of the shifter area-- really thought that was going to be the hard part until I tilted the motor as well, but I could only get about 1" of separation.
I'm assuming that once I clear that one stud at the top of the bell housing that I'm clear of the input shaft as well (ie. probably why they did that).
Greg O.
Enzo1944
Sep 6, 2015 08:57 AM
