OK, I'm incompetent.
Old Dec 23, 2002 | 02:21 AM
bobbitt's Avatar
I'm having a bitch of a time fitting in the RB header for some reason...Can anyone give me a tip or two?..I'm doing this w/out the benefit of anyone's help....Should I start from the front...the back...? etc...thanx, gentlemen.
Old Dec 23, 2002 | 03:38 AM
RotorMotorDriver's Avatar
Seven Is Coming
I did mine out of the car, but it seemed simple enough...Unbolt the old stuff, bolt the new one on. Maybe you could be more specific on which part you are having trouble with? What you have done so far, and what you think you need to do.
~T.J.
Old Dec 23, 2002 | 04:57 AM
bobbitt's Avatar
I got everything off, I'm havin' a little trouble bolting up the header...it's such a tight fit, I thought one of ya might have a helpful hint. Read-rookie
Old Dec 23, 2002 | 01:46 PM
mazdaspeedrex's Avatar
DIRTY RX
Are you sure you have the right header? i.e. 12A or 13B When I put mine on I started by bolting the header on the engine then hooking the rest of the exhaust up. I just put a new gasket on yesterday and it was a little morr difficult to line it up right but a little pushing and pulling did the trick. I also have a little more room without the stock carb and emissions crap.
Old Dec 23, 2002 | 02:04 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
front to back
best way to do anything
even females
Old Dec 23, 2002 | 05:04 PM
Project84's Avatar
Open up! Search Warrant!
Originally posted by MIKE-P-28
front to back
even females
Roger that (top to bottom is a suitable alternate procedure)
Old Dec 23, 2002 | 06:21 PM
onepointone's Avatar
i say what i want
when i did mine, i jacked the car up, and mounted it from the bottom, then had my dad do the top bolts and i did the bottom.
Old Dec 23, 2002 | 07:19 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
What specifically is interfering with the header?
Old Dec 23, 2002 | 07:40 PM
pratch's Avatar
Mazspeed.com
I had clearance issues with the stud/hole alignment when I did mine (pace setter design but same theory). ended up enlarging all 4 holes to make it fit, but fit it finally did. Once it's on the rest should be pretty easy - just make sure the header fits before you try and attach everything else.
Old Dec 23, 2002 | 08:53 PM
MarkPerez's Avatar
Tennis, anyone
Headers ??? huh,,easy enough,, use the gasket and make sure everything aligns (studs)If the gasket doesn't match, spot-on to the engine,wrong headers.
Old Dec 23, 2002 | 11:58 PM
specRX7_22's Avatar
dont you wish everything fit as well as it does on "Two-Guys Garage" or "Dream Car Garage" on speed channel? everything seems to just glide right into place no problem. lol
--eric
Old Dec 24, 2002 | 03:19 AM
Seven Is Coming
Yeah, lol I know. But in reality, my engine kinda "fell together" like that for once. I had it out on a stand, and just started with a bare block and started bolting everything on from there. Oil pan, resurfaced flywheel, clutch, bearings, intake manifold, header, carb, t-stat, t-stat housing, etc. It was nice to be like those damn shows where everything was brand spankin new and went all together .
~t.J.
Mombodogs
Oct 17, 2005 07:49 PM
