Chra
Old Dec 21, 2002 | 11:51 PM
Chra
What does CHRA mean on turbonetics turbos? and where could i get oil and coolant lines to make my own 60-1 Turbo kit ? Sorry for not searching on the lines buti figured id just ask while i was asking about the CHRA
Old Dec 22, 2002 | 12:25 AM
13BAce's Avatar
On a long vacation
CHRA is the cartrdge assembly. You can just use SS braided lines and AN fittings to make oil coolant lines.
Old Dec 22, 2002 | 12:33 AM
and SS braided and AN fittings for water coolent too? and what manifold are you using for the T 78 on your vert?
Old Dec 22, 2002 | 09:04 AM
jeff48's Avatar
Rotorally Challenged
CHRA stands for Center Housing Rotating Assembly
Old Dec 22, 2002 | 02:58 PM
13BAce's Avatar
On a long vacation
You can run SS braided lines for the coolant, but rubber hose would work just fine. The only downside would be that the rubber would wear out from the heat. You don't really NEED to run a water cooled bearing housing, unless you insist on it.
I used an HKS cast iron manifold for my T-78. It worked really well for me, but the only downside was that the manifold was undivided and the T-78 is divided. That's supposed to give a little more lag than a divded/divided setup. I sold that setup to my friend, and he made 499 RWHP at 22 PSI(still needs more tuning). So it must do ok.
If you need to know how to set up the water/oil lines let me know. I'm just too lazy to give a long explanation right now.
Old Dec 22, 2002 | 07:38 PM
lol yeah i'd like an explanation ifu could if u have aim we could talk on there or else u can PM me if u want too or just post it its upto you
dradon03
Sep 18, 2015 05:57 AM
younG_Gunner
Sep 9, 2015 08:26 PM
Shainiac
Sep 3, 2015 10:08 AM
DAVIDP
May 16, 2010 07:00 PM
