clutch?
Old Dec 17, 2002 | 10:09 AM
edd's Avatar
edd
clutch?
When I accelerate from 3k rpm in one of the upper 3 gears the car feels like it is in nuetral.It will rapidly shoot up to around 4500k with no acceleration.It then will drop back down and accelerate normally.The car has never done this in first or second.Any ideas?
Old Dec 17, 2002 | 10:24 AM
Rated R1's Avatar
Oji San
Sounds like a slipping clutch to me.
Old Dec 17, 2002 | 10:29 AM
Turbonut's Avatar
Slipping clutch. Either worn clutch or weak pressure plate. In lower gear rpm rises rapidly a/c of lower overall ratio. Less resistance. In higher gears, it takes more force to get everything moving. Engine trying to spin up quickly, but with higher overall ratio more resistance. Hope this helps.
Old Dec 17, 2002 | 10:30 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
yep, definitely the clutch.
Old Dec 18, 2002 | 08:35 AM
edd's Avatar
edd
Thanks for the help.
Old Dec 18, 2002 | 10:27 AM
DamonB's Avatar
Turbonut nailed it. Clutch has gone bye-bye.
Old Dec 18, 2002 | 12:47 PM
The ACT street-strip is a great unit. I posted a thread up here in the third gen section about it.
Old Dec 18, 2002 | 01:58 PM
MichRX7's Avatar
You should probably upgrade to a stainless steel clutch line.
http://66.216.67.51/product.asp?0=206&1=334&3=560
For $28 it is well worth it.
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
