need advise oil cooler leak
Old Dec 16, 2002 | 12:40 PM
i have a leak in my oil cooler or some line around it could that cause low compression
Old Dec 16, 2002 | 01:01 PM
specRX7_22's Avatar
i dont think so... mine leaks and all i do it throw some Oil-dry in that undertray until it falls off, then put new stuff on lol.
--eric
Old Dec 16, 2002 | 01:38 PM
GatorRX's Avatar
Do you mean 'low oil pressure'?
No, it can't. You probably have a bad guage or sender if you are referring to low oil pressure...
Old Dec 16, 2002 | 02:21 PM
MarkPerez's Avatar
Tennis, anyone
If you run the car low on oil, that could effect how the compression is, see ,, the rx7 uses oil by design, and it uses oil from the oil pan,if you've got a leak, park the car somewhere that is clean for awhile then move it and see where the leak is,,,for sure. but low 'rotor' compression is not effected by the oil cooler directly.
hope that helps.
sypath
Aug 16, 2015 12:06 AM
