Haltech Need to know how to hook up factory tach on 2nd gen w/E6K
Old Dec 15, 2002 | 09:41 PM
pistonsuk's Avatar
just wondering (if it is possible) how to use the factory tach in my '87 t2 with the E6K? what wires need hooked up? has anyone done this?
thanks,
justin
Old Dec 16, 2002 | 05:12 AM
TonyTurboII's Avatar
Glock Lover
You shouldnt have to do anything. Did you install one and find yours not working?
Old Dec 24, 2002 | 08:55 PM
Andrew's Avatar
Let me guess; you're not using the factory coils/igniters? If you <u>are</u> using the factory units, then make sure you've left the existing wires in tact and only tap into what you need to. If you <u>aren't</u> then the aftermarket igniter should have a tach output.
Old Dec 25, 2002 | 04:26 PM
pistonsuk's Avatar
ok so the tach gets its signal from the ingniter inputs. that would explain why its not working, i cut these to hook up the haltech. so hooking up the factory ingnitor outputs should fix it?
thanks,
justin
Old Dec 26, 2002 | 04:23 AM
ReZ311's Avatar
KM48 Burnout
I got the same problem. I need to get a wiring diagram of the driver's side harness. The FSM doesn't have anything.
Old Dec 29, 2002 | 06:16 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Follow the instructions on matt the HITman's site, he spoon speeds you showing which wire to use for tach...
Of course I used s4 coil packs on a 1st gen, so maybe Im clueless here, but mine works
rgordon1979
40
Mar 15, 2022 12:04 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
