I need part recommendations.
Old Aug 7, 2001 | 11:45 AM
PraxRX7's Avatar
Question I need part recommendations.
I want to obtain roughly 350 HP (at 12-15 PSI) to the wheels of my T II RX-7 '89.
I am currently running 209ish HP at the wheels from a custom port job. Money isn't a problem, I want top of the line stuff. Digital, reprogramable ECU, all the electronics needed/recommeded as well as any turbo upgrades (I want to run 15-25 PSI adjustable digitally if possible).
Sway Bars, Struts, Springs, Suspention, exhaust, flywheel (if necesary), air intake, rad/intercooler upgrade (recommeneded front mount?), Boost controllers, fuel controllers, etc.
I want to know what would be ideal for my car to achieve such a goal. I have parts lists right now, but I want to know the real loe down before I start bolting stuff on and drilling holes in my frame =)
Old Aug 7, 2001 | 11:46 AM
PraxRX7's Avatar
Also...
I also don't really want custom gaskets and rotors if at all possible...but I definitly need to upgrade my apex seals...any recommedations on that?
Old Aug 7, 2001 | 11:55 AM
PraxRX7's Avatar
Can't forget about transmissions
I am also told I should upgrade my Transmission because it won't be able to handle the power.
Old Aug 7, 2001 | 01:58 PM
flubyux2's Avatar
Thats not an FC...
ok, im not a T2 kinda guy, but here goes:
Haltec E6K computer
Spearco or Greddy FMIC
3mm apex seals
Full or half dog cut gearset for ur tranny..if they make it.
Ultra light aluminum flywheel
street/strip clutch, sprung disc. or Centerforce dual friction
HKS GTspec wastegate
HKS BOV.
check out RX7.com, mazdatrix.com, or the rx7 store that sponsors this forum. optauto.com has lots of parts too.
Old Aug 7, 2001 | 02:54 PM
rx7style's Avatar
Rotary Elite
Re: Also...
You don't need 3mm APEX seals. That requires rotor machining, and if you don't want to change the internals, that's not the way to go. Look into carbon race seals; the 2mm are just as durable as ceramic 3mm seals.
Hmmm, and aren't you patient! Aren't there other things to do with the car before you start slapping on components? Last time I saw your car it needed some "Cosmetic" work, or maybe Matt fixed everything I don't know...
Old Aug 7, 2001 | 03:04 PM
1FastT2's Avatar
Add a bigger turbo to that list..............
Old Aug 7, 2001 | 03:07 PM
flubyux2's Avatar
Thats not an FC...
Rx7style
lol, cosmetic eh? well, maybe this guy follows the same philosphy as me: "id rather be fast and ugly than slow and pretty"
Old Aug 7, 2001 | 04:00 PM
rx7style's Avatar
Rotary Elite
I'll know tonight if he comes to the RX-7 meeting!
Old Aug 7, 2001 | 04:09 PM
Scott 89t2's Avatar
SOLD THE RX-7!
NO carbon seals for turbo!! you'll blow them the first time you boost. they are for non turbo only.
you want full To4 turbo, to4 manifold, external wastegate.
bigger fuel pump. 4 720cc injectors or bigger. haltech ek6, adj. fuel pressure regulater. ported engine. 2mm seals are fine for that power. 3mm just lets you make a mistake or two. big intercooler. I'd go custom, the greddy and hks premade ones are too small for this.
my friends doing this setup as week speek
http://www.1300cc.com/howto/how2/adrian.htm
Old Aug 8, 2001 | 11:15 PM
PraxRX7's Avatar
are the front mount IC's from HKS and GREDDY to small?
Do you know anyone that can make custom ones for me?
Old Feb 28, 2002 | 04:35 AM
twister's Avatar
Talk to Guru Motorsports, they do great work for me.
Diffs & dogboxes, fantastic!
www.gurumotorsports.com
Old Feb 28, 2002 | 10:05 AM
RETed's Avatar
Re: I need part recommendations.
You want the best of the best?
MoTeC M800 - $6,000
Turbo - Garrett Ballistic Concepts or HKS GT-series turbo - $4,000
Custom stainless steel turbo exhaust manifold - $1,200
Tial 55mm Race wastegate - $1,500
Sway bars - custom speedway splined set from Tri-Point Engineering $800
Springs - see dampers
Dampers - Moton or JRZ, $3,000 per corner
Exhaust - Titanium race, see JIC dealer
Intercooler - GReddy, Blitz, A'PEXi (JAPAN SPEC) front-mount, $2,000
Boost Controller - HKS Pro, $1,300
Fuel Controller - see MoTeC
What?&nbsp Another troll?
-Ted
Old Feb 28, 2002 | 10:06 AM
RETed's Avatar
Re: Also...
Ianetti ceramic apex seals, $400/each x 12 for entire engine
-Ted
Old Feb 28, 2002 | 10:07 AM
RETed's Avatar
Re: Can't forget about transmissions
Stock drivetrain can handle it.&nbsp If you want to waste more money, HKS sells a dog box for $8,000-$9,000.&nbsp Mazda Competition sells there PBR trans for about the same price...
-Ted
Old Feb 28, 2002 | 07:28 PM
twister's Avatar
Re: Re: Can't forget about transmissions
-Ted
And Guru is much stronger and better priced option.
Old Feb 28, 2002 | 07:52 PM
RETed's Avatar
Re: Re: Re: Can't forget about transmissions
I have a problem believing their drop-in dog gears sets can handle more torque.&nbsp I've heard of transmission case flexing from 500+lb/ft of torque when applied to FC/FD cases.&nbsp Having the dog gears in the stock casing does not prevent this flex.
For $5k, I'd rather buy a Jerico or a G-Force and run an adapter plate to the 13B/20B.&nbsp Add shipping to the whole deal, and it's a significant price to pay in the U.S.
-Ted
Old Mar 1, 2002 | 01:59 AM
fcturbo2's Avatar
Re: Re: I need part recommendations.
-Ted
Those figures scares the hell out of me!..hahaha
I'll settle with 189hpTII
Old Mar 1, 2002 | 02:14 AM
Scott 89t2's Avatar
SOLD THE RX-7!
dam, an old thread!!
Old Mar 1, 2002 | 02:39 AM
twister's Avatar
Re: Re: Re: Re: Can't forget about transmissions
-Ted
In the kit is not only the gearset but also a billet sump (designed to not only store more oil but also adds heaps of case rigidity) and optional bearing spread support plate to solve this flexing problem! Shipping from/to the US is SFA (Sweet f__ all) these days, and by keeping your stock case you are still legal for street drags etc! It is that strong that you will see them soon in many front running drag cars in the US, just wait and see! Several teams have them planned already.
Old Mar 1, 2002 | 11:53 AM
RETed's Avatar
I guess I'll wait and see, cause I don't have the money right now.
If it works, I'll be calling for at least 3 sets, cause I've got 3 of them in the works right now.&nbsp Thanx for the info!
-Ted
Heedlessone
288
Sep 16, 2018 07:22 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
