how the turbos work
Old Dec 13, 2002 | 09:49 PM
urgirlwantsme's Avatar
how the turbos work
ok im new to the rx7..once again i have a 94 which i dont even have yet its getting shipped across country to me..anyway..how do the turbos work does one come on at a certain rpm and then the other or what..how does it work..and ya i know im leaving myself open for all the **** to talk **** but i need to know ..
Old Dec 13, 2002 | 10:03 PM
Mahjik's Avatar
Mr. Links
Arrow
http://www.scuderiaciriani.com/rx7/boost_test.html
Old Dec 13, 2002 | 11:31 PM
half past twelve's Avatar
Didnt you say in your last post, that your secondary was not coming online? But now the car is being shipped across the country to you?
Old Dec 14, 2002 | 01:58 AM
spurvo's Avatar
don't race, don't need to
A REALLY helpful site for this is
http://www.autosportracetech.com/RX-7/rx7stuff.htm
Old Dec 14, 2002 | 02:44 AM
turbojeff's Avatar
Do it right, do it once
Basics...
A turbo is a air pump. A turbo uses exhaust gasses (very hot and still expanding) to drive a impellor (think high performance pinwheel) attached to a shaft attached to another impellor. The other impellor forces air into the engine. If there is more air then the engine requires more fuel, this means more power.
The first turbo comes on as soon as there is enough exhuast gas to spool it up. Stock or bolt on mods they should give pretty decent boost by 1800rpm under heavy load.
Second turbo comes on at 4500rpm.
Jeff
Old Dec 14, 2002 | 03:25 AM
fdslave_g's Avatar
A capital FD barbie
the out flow air from your engine will spin the turbo fan that will pump more good air into your rotor. More air means more fuel and better, more powerful combusion. That give your engine more power without having more rotor or larger one.
I suggest you to go read www.howstuffworks.com
I hope that helps
cristoDathird
28
May 30, 2019 08:47 PM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
