removing subzero tank
Old Dec 12, 2002 | 08:33 PM
82transam's Avatar
Never Follow
well, I'd search for this, but as we all know its down. Anyway, I just want a simple answer on this, I'd like to avoid a big discussion if possible. I'm finally getting around to yanking the subzero starting tank on the 83 S and just want to confirm something. Is it as simple as just unplugging it form the wiring harness, removing it, and plugging the hole on the carb? or is there more to it? do i have to do something about the wiring or just leave it hanging there? TIA
Old Dec 12, 2002 | 08:35 PM
faye x7's Avatar
brilliantly stupid
Send yours to me...I was checking mine out and it's got a crack on the bottom.
Old Dec 12, 2002 | 08:37 PM
Keaponlaffen's Avatar
Unplug it, unplug the hose, follow the hose back to the carb, cap off the line into it, and pull the tank off the fender. End of story... no longer does your subzero tank take up useful engine compartment space... doing nothing...
Jeff
Old Dec 12, 2002 | 08:40 PM
82transam's Avatar
Never Follow
thanks dude, just what i wanted to hear.
faye x7: just remove it dude. If you really want one i have a spare on my parts car. pm me if you want.
Old Dec 12, 2002 | 08:44 PM
faye x7's Avatar
brilliantly stupid
Oh..don't really need it then?
Old Dec 12, 2002 | 08:45 PM
it's useless... if the motor DOES work, the line's probably plugged up... and if the line's not plugged up, it really doesn't do anything anyways, because it only works below 30* Farenheit and I don't think your carb would freeze up anyways... unless you hosed it down with water the night before.
I ripped mine off like a day after I got my new engine in.... haven't missed it since...
Jeff
Old Dec 12, 2002 | 08:52 PM
82transam's Avatar
Never Follow
yea, its useless, the motor on mine is solid rust, and the bottom of the tank is full of scum, i'm sure the line is clogged too. Its one of the many stupid things mazda felt it nessesary to put on our cars. It's dumb, and I need that space for something else I plan on installing someday, so out it goes.
Old Dec 12, 2002 | 09:07 PM
faye x7's Avatar
brilliantly stupid
roger that
Old Dec 13, 2002 | 11:05 AM
alien_rx7's Avatar
Interstate Chop Shop CEO
Mine are off too on all three cars though I still have them laying around in the shop. On all of them, the motors are rusted and corroded. Useless, take it off.
Old Dec 13, 2002 | 12:58 PM
faye x7's Avatar
brilliantly stupid
What's a good way to plug up the hose to the carb?
Old Dec 13, 2002 | 01:05 PM
Rx7carl's Avatar
Airflow is my life
vacuum cap works great.
Old Dec 13, 2002 | 06:04 PM
I actually don't even think you have to cap it off... only thing being that it might suck air in when it drops below the right temperature... who knows...
Old Dec 13, 2002 | 06:15 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
You got it, just unplug, cap and remove, throw in garbage can All done
Old Dec 13, 2002 | 11:51 PM
82transam's Avatar
Never Follow
I don't know if you would really have to cap it either, that hole is the size of a pin. I guess I will just to be safe, but its probably not nessesary.
Old Dec 14, 2002 | 12:09 PM
MIKE-P-28's Avatar
I guess dirt and gunk would eventually plug it. But I think it looks better capped off
Old Dec 14, 2002 | 12:12 PM
so much for not having an elaborate thread eh?
Jeff
Old Dec 14, 2002 | 12:27 PM
faye x7's Avatar
brilliantly stupid
How do I get that little bastard out?
yes...i'm a n00b
Old Dec 14, 2002 | 12:38 PM
it just pulls off the fender, slides up....
Jeff
Old Dec 14, 2002 | 01:51 PM
82transam's Avatar
Never Follow
Yea, it might be a little hard to get out, mine seemed to be stuck, but if you wiggle it around it should come free. After I started this thread I thought about it and kinda figured it would turn out long, oh well, its fine maybe It will help some people since we can't search.
Old Dec 14, 2002 | 01:56 PM
faye x7's Avatar
brilliantly stupid
Mine didn't slide up...it slide to the side and it was a little stuck heh...took a good tug to get it off. heh
Old Dec 14, 2002 | 02:01 PM
82transam's Avatar
Never Follow
sounds about right, mine was stuck and I got annoyed so I just started yanking on it, ended up breaking it, but that ****** is outta there
Old Dec 14, 2002 | 03:19 PM
alien_rx7's Avatar
I must be different, I didn't even try sliding mine out, I just disconnected the hose and harness and then just wrenched it off bracket and all.
Old Dec 14, 2002 | 09:19 PM
82transam's Avatar
Never Follow
You could do that, but its easier to get at the two bolts after the tank is off IMO.
Old Dec 16, 2002 | 08:35 AM
alien_rx7's Avatar
Yeah, I know that now
Old Dec 16, 2002 | 06:36 PM
Maguire's Avatar
Born 2 Brap
i was just thinking about this yesterday. thanks for asking the question for me!
