Corvair turbo's on Rotaries?
Old Dec 12, 2002 | 10:31 AM
inittab's Avatar
I read your email
Question Corvair turbo's on Rotaries?
Okay.... someone just IM'd me and told me that the Corvair turbo can bolt right up to the flange of the throttle plates on a 12a. Sounds fiiiiishy to me. What do ya'll think? Anyone ever hear of this?
eBay - NEW Corvair Turbo Turbocharger Carbs
Old Dec 12, 2002 | 10:42 AM
sounds fishy to me cuz the thing costs 9$'s.... or did i just read it wrong ?
Old Dec 12, 2002 | 10:43 AM
wait nm my bad
that was the bid first bid lol.... i saw the 152$ just now.... but it looks great, not like a little fabricating couldnt do the trick ...
Old Dec 12, 2002 | 08:29 PM
pjr's Avatar
pjr
Mr May 2011
You mean I should have kept the '63 Corvair Monza Spyder that I had during college? Damn...I knew that car would be good for something SOME day...
Old Dec 12, 2002 | 09:26 PM
rotor vs. piston's Avatar
Function > Form
Old Dec 13, 2002 | 01:08 AM
Keaponlaffen's Avatar
*shudder*...... monza......
Jeff
Old Dec 13, 2002 | 06:10 PM
White84SE's Avatar
U sUx0rz @ THe IntaRwEB!
I really don't know if you'd want to use a Corvair turbo on an RX-7.. they can barely move enough air to support the 164 cubic inch flat 6 in the later 'Vairs at 5k RPM let alone even a 12A trying to push 7k ...
--Danny
Old Dec 13, 2002 | 06:12 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
2 words not spoken well when put next to each other LOL
NEW REBUILT 150 HP turbocharger
Old Dec 13, 2002 | 06:35 PM
Rx7carl's Avatar
Airflow is my life
The later model vairs (65-69) turbos have a much improved impeller/turbine wheel shape. Those engines made 180 hp with the same engine/carb. So if you can do this (i.e. it fits a 7), use the later style, or get the 150 if its cheap and replace the cartridge. I believe it's a rayjay unit. Thats what all the guys did way back when to boost the hp in their 63-64 150hp spyders. Been years since I messed with my vairs. I still got a barn full of vair parts at my dads house. Maybe con him into sending me some of my old turbos so I can look into it. SO this would bolt up how? supposedly?
Old Dec 13, 2002 | 06:37 PM
Rx7carl's Avatar
Airflow is my life
Oh and clarks corvair parts in Mass. used to sell rebuilt vair turbos. If theyre still around I bet they got em
Old Dec 13, 2002 | 07:17 PM
Project84's Avatar
Open up! Search Warrant!
I would be willing to bet that some sort of fabrication would be necessary unless the seller already modded it to fit a rotary. And as someone else mentioned, can a rotary breathe that deep?
Old Dec 13, 2002 | 07:22 PM
gamble302's Avatar
roadkill hats rock
sounds verrrry fishy to me. what about the exhaust manifold for instance :-P ? and why do that when you can get a stock TII mani and turbo and round out the holes from what i hear, still no solid proof til i do it or someone beats me to it, but it sure does sound easier than that. and carbs are easy to come by compaired to turbos. the only hard part is the piping. anyone know who can make me a good manifold for my 12a that'll fit a t04e or should i make it mahself muhahahaha
Old Dec 14, 2002 | 08:06 AM
pjr's Avatar
pjr
Mr May 2011
They are still around!
Old Dec 14, 2002 | 08:09 AM
RotorMotorDriver's Avatar
Seven Is Coming
MoreMazda has a 2nd gen turbo/manifold with an adapter plate he made to space it out a little, but it wouldve fit just rounding out the holes.
~T.J.
Old Dec 16, 2002 | 01:58 PM
GatorRX's Avatar
Corvair turbos had no external cooling lines on them, they'd last 10 minutes on a rotary.
Old Dec 16, 2002 | 03:45 PM
Rx7carl's Avatar
Airflow is my life
hmmmmm good point! Been a while...........
Old Dec 16, 2002 | 07:00 PM
pjr's Avatar
pjr
Mr May 2011
...which is not a hell of a lot different than on the 164 cubic inch air-cooled flat 6...
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
