FD Wheel Hub Removal
Old Dec 11, 2002 | 10:36 PM
caffeine655's Avatar
Any sugestions on pulling the hub off to replace a stud? a gear puller maybe, or is there an easier way to replace a stud... thanks
Old Dec 12, 2002 | 04:40 PM
anyone? im sure im not the only one that has had a stud break off...
Old Dec 15, 2002 | 09:30 PM
BLKTOPTRVL's Avatar
I replaced a hub recently...
Remove the disk from the car, then take it to someone who has an impact hammer to remove the two screws holding the hub in... after removing the two screws the hub falls out.
I took it to sears who loosened the screws at no charge. You may be able to rent an impact hammer at a local parts store.
Good luck.
Old Dec 16, 2002 | 05:32 AM
inukai's Avatar
Hi
1. remove a brake caliper
2. remove two bolts to Brake rotor ring
3. remove a hub cap shown as #26-071
4. remove a big nut shown as #33-042
Big nut is the Metric, 35 mm
Snoopy FD
Dec 8, 2015 01:45 PM
TheAsset
Sep 5, 2015 04:36 PM
fidelity101
13
Aug 31, 2015 07:47 PM
