Holly question
Old Dec 11, 2002 | 05:27 PM
Heath's Avatar
MAGNUM SE7EN
Holly question
A buddy has a holly carb that will fit my 85 gsl. He said I can have it for $50. My stock Nikki needs a rebuild so I am thinking about going with the Holly if all is well.
The search function has been disabled, otherwise I would go that route. Does the Holly have to be a certain model? If so, which models work. Any other necessary modifications when going with a Holly? Please send any pro's and con's my way. It will be greatly appreciated!
Old Dec 11, 2002 | 05:32 PM
diabolical1's Avatar
if you've got stock ports, i believe you need the 465 Holley carb, unless you know how to rejet a 550. also, will you be getting a manifold with it?
there was a pretty good thread on Holley's recently ... i'll try to find it and link it.
Old Dec 11, 2002 | 05:39 PM
search function? HA ... i don't need no stinkin' search function!
Hope this helps
Old Dec 11, 2002 | 10:13 PM
Heath's Avatar
MAGNUM SE7EN
Thanks for the info!
Old Dec 11, 2002 | 10:33 PM
Heath's Avatar
MAGNUM SE7EN
How much am I looking at for a manifold to fit the Holly carb?
Old Dec 11, 2002 | 11:22 PM
mperformance's Avatar
it's holley...not holly
Old Dec 11, 2002 | 11:56 PM
joelwahid's Avatar
204 bones from mazdatrix. http://www.mazdatrix.com/r-holley.htm
Old Dec 12, 2002 | 01:53 AM
corkbone's Avatar
if its not off a rotary, watch out
You might have trouble getting it to run right. The ones from racing beat have been modified internally to run correctly for rotaries, but then again there is a guy here in san diego who buys the 600cfm from pep boys or something? and can make it work on a rotary. just make sure you know what your doing. good luck
Old Dec 12, 2002 | 09:14 AM
Heath's Avatar
MAGNUM SE7EN
I'm not sure I'll go the Holl E y route since it may be a real pain to tune. I may just go with a rebuild on my Nikki. Decisions....
Old Dec 12, 2002 | 11:10 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
It depends on your plans,I think you may be able to run a reworked Nikki carb on a street port nice,BUT dont expect high HP gain compared to a Holley,
Im running a 600 double pumper /mechanical secondaries not that POS vacume **** you get at PepBoys for $199.99
Heres what I got 4776
Dual feed double pumper.
On a RB intake,with a Holley blue fuel pump which I thinkis the best for its price with a fuel pump regulator for $110.
I run all this on a stock port engine with 110k original miles on it and run 15s,Im not sure of my exact RWHP,but im satified for what I got.
Old Dec 12, 2002 | 11:16 AM
SoRRoW's Avatar
Heres what I like about Holleys,
Rebuild parts are cheap,
Upgrade mods are cheap,
100s of diffrent ways to mod it,
a Holley is one of the most basic carbs to tune.
Heres somethings I dont like,
If you know anything about drag racing,On a V8 they have to put jet extensions cause whenthe car launches the fuel rushes to the back of the carb,
WELL on a rotary the front of the carb(primarys) sit the the left of the car,YOU have to install notched floats and extensions,NO biggie
You can have shops do work on a Holley for your rotary,MOST drag guys run Holleys,MOST SCCA,Road Race,Auto X like running Webbers,Mukinu,Delatoro.
Some guys keep the stock carb rework it and use it on a 79-80 Intake (Which I have foresale).It just depends what your tring to acheive,and not worried abotu gas milage.
Old Dec 12, 2002 | 11:26 AM
Cloud's Avatar
Boing
Since the racing beat street-port kit COMES with a vacuum secondaries carb...I don't see why a simple Holley #1850 (generic 600cfm carb) couldn't be adapted to rotary applications.
Holleys are easy as hell to modify and play with - if I planned on keeping the 12A in my car, I'd throw a used, self-modded Holley on a Racing Beat manifold just so I could easily tune it.
-Jacob
Old Dec 12, 2002 | 11:55 AM
zyounker's Avatar
root
Holleys on rotaries suck ***..
I had one for about 2 years.. You can modify them to make them ok though..
1st you need to get the center pivot floats, because the position the holley sits, when on a rotary is sideways, so on turns it bogs..
Now, 600CFM on a stock port 12A is WAY to large!!!
600CFM would be inline for a large 12A bridge port.
Even a 550CFM is too big for a stock port 12A, you should go with a 465, that is about the best for a stock port 12a..
-Zach
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
