SE 13B into non SE
Old Dec 11, 2002 | 05:08 PM
82transam's Avatar
Never Follow
SE 13B into non SE
I would search for this if I could, since i'm sure its come up before. anyway, a guy I talked to today has a 84 SE that runs good etc, but is rotting away to nothing. He's intersted in buying my 83 GS (solid body, great interior, shitty engine) to swap his engine, trans, suspension etc into. Now, I know the suspension is a bolt in thing, but what about the engine and trans? I assume physically getting them in is pretty easy, but what about wiring? Is there a way to simply change the whole under hood wiring harness? or would this require a lot of custom work? thanks guys.
Old Dec 11, 2002 | 05:15 PM
diabolical1's Avatar
Re: SE 13B into non SE
Originally posted by 82transam
... would this require a lot of custom work?
i don't know if the harness will require "custom" work, but i do know that it will require a lot of time and labor-intensive work ... i may be wrong though.
however, you should remind him about the fuel tank and lines ...
Old Dec 11, 2002 | 05:16 PM
WackyRotary's Avatar
standard combustion
you will need some kind of mod'd engine mount or a Racing beat mount meant for this conversion. Most of the other stuff is pretty straight foward and is just a matter of swapping. Don't forget to get the master cylinder and purportioning valve from the SE also.
Old Dec 11, 2002 | 05:20 PM
82transam's Avatar
Never Follow
oh yea, i totally forgot about the gas tank, hmmm, this could be more work than hes looking for.
Old Dec 11, 2002 | 05:22 PM
purple82's Avatar
Absolute Power is Awesome
The rear suspension chassis pickup points are different between the 83 and 84.
Old Dec 11, 2002 | 05:28 PM
the stock SE mounting bracket will work just fine.
Old Dec 11, 2002 | 05:33 PM
hornbm's Avatar
FD > FB > FC
why would you need to worry about the gas tank?
Old Dec 11, 2002 | 06:39 PM
rxguru's Avatar
completely wankelfied
I'm not sure on the tank but the fuel pump and lines will need to be swapped cause efi is some high pressure stuff. If concerned about the wiring just ditch the whole EFI thing and go with a Holley like I did. Makes more power than the EFI due to lack of restricive intake system.
Old Dec 11, 2002 | 06:47 PM
82transam's Avatar
Never Follow
well, if it were my project i wouldn't even bother with the SE engine to begin with, I'd go right to a NA 89 engine, but its up to the guy. i'm just trying to get an idea of what would be involved if he were to buy the car and go through with the conversion.
Old Dec 11, 2002 | 07:25 PM
okay ... maybe i'm showing my ignorance here, but i've never had an SE. isn't the SE's fuel pump in it's tank? that was why i brought up the whole fuel tank issue. if it's not ... then i apologize.
Old Dec 11, 2002 | 07:35 PM
680RWHP12A's Avatar
the engine mount needs to be slotted unless you use the entire SE crossmember....all suspension componenets will switch over no problem! i have done it several times.....the gas tank will also interchange no probem, the fuel pump is external in the same place as the non efi type... (some bracket modificatitons needed)is the car going to retain the efi or are you going carburated?
Old Dec 11, 2002 | 08:48 PM
Rotor13B's Avatar
Wassup!!
I thought it didn't matter much between the SE engine and the 2nd gen motor if you went carburated, or is that only for the S4 engines?
Old Dec 11, 2002 | 11:35 PM
hornbm's Avatar
FD > FB > FC
I havent started to worry much about the fuel lines for my 89 swap... but I'm going to have to deal with them soon enough.
What would you reccomend I do to the fuel lines to make them safe for the swap?
Old Dec 12, 2002 | 05:33 PM
hornbm's Avatar
FD > FB > FC
BUMP
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
