boost, vacume, how nitrous works on a carbed motor?
so normally, on a n NA car, the engine creates a vacume that sucks air from the carb, right?
when you spray nitrous, it is usually se tup to squirt in to the manifold, right? at 900psi(reccomended bottle pressure), what keeps the pressure of the nitrous in the manifold from pusing the gas/air mixture backwards through the carb?
is it just that the engine produces way too much vacume for this to happen, or is it something else?
~T.J.
well ... first off, let me say that i've never used NO2 before, but i'll offer my take on your question.
i'd guess that when they fill those bottles, it's in liquid form, right? it would require high pressure to keep them that way until it's being used, in which case it would return to gas as pressures equalize, and like rotormotordriver said, get "easily sucked into the engine."
jetlude
Aug 18, 2015 04:53 PM
