Changing your fender emblems....
Old Dec 7, 2002 | 10:54 AM
jimtesla's Avatar
Hey
Got two new fender emblems.....What is the best way to get the old off and the new on.......without having to take the fenders off.........Any tricks.........?
Jim
Old Dec 7, 2002 | 10:57 AM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
Are they glued or clipped? If glued try a hair dryer to heat and gently pull at them to remove them, not sure what is recomended to reapply, sorry!
Old Dec 7, 2002 | 11:10 AM
jimtesla's Avatar
My emblems are clipped orig.....
New have clips...........
Old Dec 7, 2002 | 11:29 AM
gamble302's Avatar
roadkill hats rock
all you have to do is remove the inner piece of plastic on the fender well, you should be able to reach up from behind and do your thing then. not that ive replaced fenders before. stupid tree....
Old Dec 7, 2002 | 07:20 PM
85RX7GS's Avatar
Easier than that - gently pry the old ones off with a putty knife or something. You'll probably break some clips, but I don't think it'll be that important
With the emblems removed, the clips can be easily picked out of the fender.
Old Dec 7, 2002 | 07:29 PM
jerij's Avatar
Putty knife, yes. Usually the barrel nuts are left sticking in the sheetmetal. Good luck pulling them out. If the new badge has the same anchors, though, you can just keep the barrel nuts in place and pop your new emblem in place. VB has the nuts if you need more.
jeryj
Old Dec 7, 2002 | 10:21 PM
jimtesla's Avatar
I pryed them off and popped the new ones on........
Very easy............Looks great..............
Tried to go from behind with my hand..........and a tugged on the emblem.....an it started coming off
Thanks
Jim
