Strut Tower Brace, will it fit w/ camber plates?
Old Dec 6, 2002 | 11:22 PM
FD Racer's Avatar
sold the FD...kept the FB
Does anyone running ground control caster / camber plates have a strut brace installed?
I worried some of the adjuster bolts wont clear
Old Dec 7, 2002 | 12:22 AM
riffraff's Avatar
smog nazi destroyer
you should have no problems.
Old Dec 7, 2002 | 09:58 AM
branca's Avatar
not a problem w/ my Cusco brace, plus it's also adjustable.
Old Dec 7, 2002 | 11:04 AM
Manntis's Avatar
add to cart
can't find that brace on their site - only 5 items for FBs
Old Dec 7, 2002 | 12:33 PM
branca's Avatar
http://www.rx7.com/cgi-local/1catalog.cgi?cat=8&part=4
Old Dec 7, 2002 | 04:03 PM
Pele's Avatar
Right near Malloy
You had to cut to install the Ground Control Camber/Caster plates? I thouth they were straight bolt on.
Old Dec 7, 2002 | 04:37 PM
HadaGSL-SE's Avatar
1st gens only
do those strut brace work well?
i am interested in getting one and was just wondering
Old Dec 7, 2002 | 06:25 PM
FD Racer's Avatar
If you want to take advantage of the plate's full positve caster adjustablity (around +6) then you need to grind towards the back of the car.
If you want to take full advantage of full negative camber, then you need to grind towards the engine. I probably could of got away without grinding the camber since I am using this as a street car. If you notice I am no where near max negative camber, but I am at full caster however.
That cusco brace looks like it will work as long as I dont increase negative camber towards the limit, which I probably never will. Thanks!
Old Dec 7, 2002 | 08:00 PM
Pele's Avatar
Right near Malloy
D@mN HomEs!!!! J00R RyDE bE tIgHt WIf fOrTy-5 dEgreEs nEgaTiVe CamBer y0! hOndA cIviCs tUrN mAd KwIK wHeN tHey ruN On dA SYdeWAlLs!!!
Old Dec 7, 2002 | 08:16 PM
RotorMotorDriver's Avatar
Seven Is Coming
OMFG!! LOL!!
~T.J.
Old Dec 7, 2002 | 09:28 PM
FD Racer's Avatar
Worrrrrrd G! dat ***** banging fool! Check it, I got this new torch....dis **** make yo car mad low, yo! Just heat them springs up, it'll be hella tight!
rkhanso
Aug 13, 2015 11:40 AM
