Too Cold now with Scoot & bumper???
Old Dec 4, 2002 | 09:17 AM
DavidDeco's Avatar
I have more fun than you.
Quick background...
2 months ago : Oil Temps 105+, Water Temps 95, Hot Florida weather. So Added Dual Oil Cooler Kit (Crooked willow), used datalogit to turn fans on early. replaced a faulty relay, added water wetter and then had Oil Temps low 90's, water temp 85-87 , air temps 60's-70's (all Celsius of course) in about 70F outside weather.
NOW with very similar temperatures I'm getting Oil Temps 75-80C, Water temps 84-85, air temps high 40's.
Last night it was cold an I saw my oil temp at one point *quickly* drop into the 60;s before climbing back in the high 70's after a minute. I thought something was wrong.
My water temps are verified by PowerFC, datalogit, and an aftermarket gauge, my oil temps are measure by my a.m. gauge, and my air tems are measured by the PowerFC/datalogit.
Is this TOO cold for my oil? I haven't even put the CF o.c. ducts on the bumper yet. My oil pressure seems to follow the same patterns as it has these past months.
I'm currently using 20W50 as I was told not to use synthetic until my rebuilt turbos broke in (engine rebuild only has 3k miles on it too, turbos about 1k).
Thanks,
David
Old Dec 4, 2002 | 09:33 AM
ptrhahn's Avatar
Correct me if i'm wrong, but shouldn't the oil and water thermostats close up in the event that the car isn't up to proper temp?
I know as cold as its been around here, i have trouble getting the car up to temp, and have seen it dip back to 79c on the PFC on the highway.
i've often thought our water thermostats are more of a on-off switch (basically wide-open once opened) than a real instrument for maintaining opperating temps
Old Dec 4, 2002 | 09:46 AM
DavidDeco's Avatar
Originally posted by ptrhahn
.....I know as cold as its been around here, i have trouble getting the car up to temp, and have seen it dip back to 79c on the PFC on the highway.
It's only about 70F here. Last night was a little "cold" by Florida standards. I'm just worried about the oil being too cold to lubricate efficiently. I also don't much faith in any thermostat to look out for me...
Old Dec 4, 2002 | 06:01 PM
DavidDeco's Avatar
bump...Is 60-70C Okay for oil then??
Old Dec 4, 2002 | 06:23 PM
apneablue's Avatar
Wow, this is a first...someone saying, "my FD can't warm up!" awesome...
Old Dec 4, 2002 | 06:29 PM
DavidDeco's Avatar
p to
Yeah, and I know your joking but what worries me is that is does warm up to 85-9if I'm at a light sometimes not moving, but then the temps drop quick usually. I just drove back over the causeway and saw a spread between 75 and 90 on that drive.
Old Dec 4, 2002 | 07:33 PM
ptrhahn's Avatar
AFAIK,
You'd want the oil temp to be around 180f (83c or so), and thats fairly well backed up by the 170f thermostat that your kit supposedly comes with. Just as a test, maybe try blocking all or a purtion of the passenger side cooler (maybe cover the opening w/cardboard), to see if the thermostat is actually sending oil there when the temps are that low or if its being bypassed. If its not flowing there, it shouldn't change anything.
This is just a guess... i don't own or have experience w/ your kit.
Old Dec 5, 2002 | 02:58 AM
JBC's Avatar
JBC
It's now in the 40's and 50's here in Texas and I have driven for extended periods where the oil temps never got past 70C or 158F. My normal cruising temp when ambient is above 80 is 75C or 165--168 F.
As far as the thermostat goes I never understood that because I have rarely seen it get to 180 deg.
Old Dec 5, 2002 | 06:36 AM
Flybye's Avatar
It's never fast enough...
and why don't you just reset the fans to come on at 90c (or the factory level) or so. The increased heat will also warm up the oil.
Or just screw that. WOT it a few times
Old Dec 6, 2002 | 01:57 PM
DavidDeco's Avatar
Just to TRY, I ran the car the other day WOT a bunch of times and tried to heat up the oil. I can get no higher than about 90.
Ill screw with my fans when I get back and see how they affect (indirectly I guess) the oil temp. I guess I wont bitch. Low is good, I was just worried maybe it was too low for proper lubrication at times.
mikedscpt
22
Oct 28, 2015 03:04 PM
vish86
Oct 1, 2015 10:04 AM
MILOS7
Sep 22, 2015 03:26 AM
