common driver side door lock problem?
Old Dec 2, 2002 | 01:28 AM
REFD3S's Avatar
hey guys,
I wanted to find out if there is a common driver side door lock problem. I remember reading a long time ago several posts about driver side door lock. The problem I am having with my door is that I have to open the lock from the inside of the car first before I can open it from the outside. Meaning, I have to open the passenger door climb in and reach over to unlock the driver side and then walk over to the driver side and unlock the lock with the key then pull on the ****. If I do anything else it will not open. Sometimes, when I try to get out of the car the door will not open so I have to reach out and use the key to unlock then open the door when I am inside. Luckily I dont driver my FD everyday so its not a HUGE problem but I want to get it fixed soon. I thought it might be a big help if I knew what to replace/fix if this was a common problem.
thanks,
sean
Old Dec 2, 2002 | 03:24 AM
BicuspiD's Avatar
Infamous...Butcher...
heres a link to the thread w/the solution I used.. still works great
https://www.rx7club.com/forum/showth...713#post685713
Frisky Arab
13
Aug 18, 2015 05:30 PM
