CWR air box install?
Old Dec 1, 2002 | 03:59 PM
Donovan's Avatar
Hi sir
How the hell do you get this in there? Is it supposed to hit everything and rub everything, and be impossible to reconnect the hoses to? I bought it from a great guy on the forum and now I am trying to install the bitch in the car. Its going next to a M2 intercooler. It is hitting the plugs on the fender well. The stock pipes cause the connections to scew sideways causing the filters to hit the side of the box. I can't figure a good way to recollect the smaller hoses without them hitting and rubbing everything and the stock BOVs gets jammed against stuff.
Old Dec 1, 2002 | 04:04 PM
CWR products are known for not fitting correctly. You'll have to modify/trim the box a little to make it fit.
Old Dec 1, 2002 | 04:11 PM
65Imp's Avatar
Performance Part Purveyor
Thank goodness,
I'm not the only one... I spent half a day getting mine, and just barely, it still dosen't sit squarely, it's totally forced in there, it looks like my old friend mr dremel will have to give me a hand!
Old Dec 2, 2002 | 01:06 AM
Donovan's Avatar
Hi sir
Great ... so any sugestions on the install?
Old Dec 2, 2002 | 07:46 AM
mks's Avatar
mks
This is a beautifully documented CWR IC install, and gives you quite a few pics and tips on the CWR air box install as well:
http://www.negative-camber.org/crispyrx7/cwric.htm
A few customizations I noted are the hole made in the bottom of the box for a crossmember bolt, the airpump supply line T, and the solution for the lower turbo intake hose being too long.
astrum
24
Nov 15, 2017 08:44 AM
Microtech
30
Apr 23, 2016 06:37 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
