do i need this?
Old Dec 1, 2002 | 02:12 PM
yodaddy's Avatar
Question do i need this?
i have been having some problems with my idle air control valve. i think that i might have it fixed but i was wondering do i really need it or can i just put a block off plate there. what good or bad things would happen if i got rid of it?
Old Dec 1, 2002 | 02:40 PM
wasabi's Avatar
Bad idle...
Old Dec 1, 2002 | 02:42 PM
yodaddy's Avatar
what do you meen by bad idle? the reason i am asking is that there are other ways that the idle is controlled not just that valve. also if it helps (because it is electrically controlled) i have a pfc.
Old Dec 1, 2002 | 02:49 PM
wasabi's Avatar
The valve is used by the computer to maintain the 750rpm idle. Don't know what happens with the PFC though. I think you still need the valve to maintain good idle under various conditions (cold, warm, etc).
-MP
Old Dec 1, 2002 | 11:35 PM
spurvo's Avatar
don't race, don't need to
Should note the stock ECU also uses this air passage to reduce afterburn on closed throttle (i.e. backfiring). Ya need it.
