Can you use 75W90 in the rear end?
Old Nov 26, 2002 | 08:49 PM
lerch32's Avatar
I ordered a gallon of NEO 75W90 for my tranny. Can I use it in the rear end as well?
Old Nov 26, 2002 | 08:57 PM
nmo93's Avatar
yeah, i just put royal purple 75w90 in the diff. the diff takes 1.5 quarts. nick
Old Nov 26, 2002 | 09:14 PM
eurautodave's Avatar
your trans will shift better with thinner oil. i'm currently running redline synthetic ATF D4. much better shifting in cold weather. amsoil gl5 in diff.
Old Nov 26, 2002 | 09:36 PM
EviLPeNeviL's Avatar
Can't live without boost.
Old Nov 26, 2002 | 11:15 PM
Mazderati's Avatar
I have Amsoil 75w90 in both my transmission and rear differential. M2 actually recommended for me to use 75w90 in both cases. Good luck.
Kyle
Old Nov 27, 2002 | 02:38 AM
maxcooper's Avatar
WWFSMD
Stock capacities are 1.4 qts for the diff and 2.6 qts for the tranny. 75W90 is the recommended weight for the diff. My diff fluid was really ugly when I drained it -- all silver from the metal in it. It seems like the car would benefit from diff fluid changes every now and then (30K miles?).
-Max
Old Nov 27, 2002 | 05:07 AM
lerch32's Avatar
Thanks guys!
Old Nov 27, 2002 | 10:26 AM
RX7SpiritR's Avatar
The Spirit of FLUFF!
Hmmmm....dude your scaring me! Maybe I too should check my diff., and my tranny. I'm kinda fearing that I have a broken 5th gear synchro though... man, will that suck. So they recommend 75W90? I think I'll go with royal purple!
Old Nov 27, 2002 | 11:28 AM
ArcWelder's Avatar
Mazda Owners Manual:
Lubricant Quality:
Diff Oil:
API Service GL-4 or GL-5
Above 0degF: SAE90
Below 0degF: SAE80W
Man Trans oil:
API Service GL-4 or GL-5(SAE 75W-90)
Above 50degF API Service GL-4 or GL5(SAE 80W-90)
If you trust a shop that's made other recommendations and has evidence that it actually gives you some benefit, great! Else, deviate from Mazda's recommendations at your own risk.
Mark
Old Nov 27, 2002 | 12:08 PM
Street King's Avatar
*** Bless Texas!
Trust me you can tell the difference if you do change the diff. and tranny fluids. For the differential fluid change, definetly get a gas mask. I almost puked. I use Mobil 1 when I use synthetics.
Old Nov 27, 2002 | 01:19 PM
what does gl-4 and gl-5 stand for?
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
