Speaker wiring diagram for FD?
Old Nov 23, 2002 | 10:36 PM
Cheuk in Seoul's Avatar
I was running a 6 channel amp. Well, the amp blew after 10 years. So I am switching to just a 2 channel amp and running the four stock speakers off of a head unit built in power. But I can't remember the stupid color codes for the speakers. Anyone have it on hand?
Thanks,
Cheuk
Old Nov 24, 2002 | 12:23 AM
unixpilot's Avatar
Check out my Mooseknuckle
Non-Bose Stereo wiring mapping
The results of tracing the standard Clarion radio are shown below.
Note that it may not apply to the Bose system which outputs preamp levels and has powered amplifiers in the speakers. There are two main connectors to the Clarion radio which may be similar to those on the Bose. For instance, there is a power supply to the speaker connectors in the doors which is not used in the Clarion setup but would need to be used to power the amps in the Bose speakers. If you are replacing the Bose setup, you will probably need to get a stereo with pre-amp outputs. In my setup there are 10 wires to one of the main connectors and 5 to the other.
Wires I traced are as follows. (Note that some of the wire colours are subject to fading!)
Note: some wires have pink, (possibly silver) rings on them as well as the colours listed below, but these may be worn off the wires.
Note: where two colours are listed, that the major colour is listed first.
Final note: this list is from an Efini RX7, similar to an R1, but it is right hand drive.
10-wire connector:
Red: Front Right door speaker
White: Front Right door speaker
Blue: Front Left door speaker
Green: Front Left door speaker
Grey/Black stripe: Could not trace - maybe front dash tweeter crossover
Red/Green: Instrument dimmer illumination connector
Green/Red: Aerial (Antenna) power lift feed
Black/Red: Could not trace - maybe front dash tweeter crossover
Blue/Red: 12v permanent supply
Blue/Black: 12v switched supply
5-wire connector:
Yellow/Green: Rear Left speaker
Yellow/Blue: Rear Left speaker
White/Blue: Rear right speaker
Blue/Yellow: Rear right speaker
Beige (light brown): Could not trace
Spade connector:
Black: Negative Earth
Antenna connections for diversity system
Large socket: Main retractable aerial mast
Small socket: Rear window built-in aerial
Old Nov 24, 2002 | 09:25 AM
Unixpilot.... Thank you very much.
Time to find the wire stripper and electrical tape.
Old Nov 24, 2002 | 04:25 PM
unixpilot's Avatar
No problem...glad to help out.. I'm doing the same thing this weekend too
Old Sep 5, 2025 | 06:55 PM
RXmfkn7's Avatar
Tenured Member: 5 Years
So I have Bose speaker harness that I want to splice a connect to an after market speaker.
I has 4 wires black orange yellow purple. Which ones is + and-
windom
Sep 11, 2015 04:48 AM
