85 GSL Brakes confused
Old Aug 4, 2001 | 01:16 AM
Winnipeg85GSL's Avatar
I thought that the front and rear discs only came on the SE, But i realized that my 85 GSL has them. Are all GSl's like this? I thought they were front disc rear drum.
Old Aug 4, 2001 | 01:29 AM
Felix Wankel's Avatar
Super Newbie
Re: 85 GSL Brakes confused
GSL's have a sunroof, power windows, better climate control, disc/LSD rear (although its different from the SE rear; it has non vented rotors, for one).
Old Aug 4, 2001 | 03:59 AM
speckamp's Avatar
8krpm is not enough
The GSL's were the top-of-the-line RX-7 until the GSL-SE's came out.
The GSL's had 4 wheel discs, LSD rear, different interior options, sunroof, ect.
The GSL-SE's added the 13B 6port FI motor, different tranny gearing, ~4.100 rear end gears, bigger front rotors, bigger, vented rear-rotors, upgraded suspension (tokico shocks and struts, higher spring rates, lowered trailing arm mounting points), bigger rims (14"), a different bolt pattern (4x4.5, I believe) and V rated rubber to the already venerable GSL.
The GSL's rear, btw shared the 3.090 ratio gearing of the rest of the 1st gen's.
--matt
Old Aug 4, 2001 | 07:55 AM
Denny's Avatar
Wink
Speckamp is right on...
For us wrenchin' Cowboys the big difference in the brakes is because the SE has bigger brake rotors the bottom bolt that halds the caliper to the backing plate is Soooooo much easier to get to and take out when your do pads, and stuff...
Denny, from the abandoned corncrib...
Old Aug 4, 2001 | 10:15 AM
Super Newbie
Yeah, I got pissed one day and made a wrench that I can get in there without having to use a prybar
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
doritoloco
Sep 5, 2015 12:41 PM
Frisky Arab
Sep 4, 2015 06:17 PM
