question for all you non-seq guys
Old Nov 20, 2002 | 10:15 PM
fd3virgin's Avatar
ok. when i have the lines hooked up to the wastegate solenoid. i get full boost or more. 12-13 psi. in all gears. but the boost spools up slow. esp in first gear. don't get full boost till like 5500-6000 rpm. when i switched to the pre-control the boost builds up quicker but boosts only to 10 psi and drops back down to 7-8 and stays there?????? wtf does anyone have this problem. i have a pfc. should it be reset or something when i switch to the precontrol solenoid or is the solenoid fucked.... my mods: intakes/cb/dp/mp/pfc/greddy smic. any help is appreciated in advance. thanks kevin
Old Nov 20, 2002 | 10:44 PM
Silver7's Avatar
This doesn't make any sense to me. Why do you have a precontrol solenoid hooked up? You need to illustrate your situation a little better.
Old Nov 21, 2002 | 03:41 PM
fd3virgin's Avatar
i don't have it hooked up at the same time. i switched from the wastegate to the precontrol.
Old Nov 21, 2002 | 07:45 PM
Silver7's Avatar
You still need to illustrate your situation a little better. This is probably why no one is responding.
Silver7's Avatar
Out of curiosity, where are you in MD?
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
