strange turbo noise, please help!
Old Nov 19, 2002 | 09:27 PM
Unhappy strange turbo noise, please help!
finally, with the help of RST3GEN, i have a 10-8-10 boost pattern. however, at full boost, i hear a noise to the effect of a cricket or locust (more at a constant tone and pitch). anyone ever hear a noise similar to this? it only happens when the car is warm and under full boost. it does happen on both primary and secondary so not likely to be a bad turbo. started just recently (after switching back to seq). before i went seq my turbo pre-control and trubo control solenoid valve were both broken.
everything seems to be in working order if it werent for the noise i keep hearing. any help would be graciously appriciated.
thanks.
Old Nov 20, 2002 | 05:26 PM
you mean to tell me out of all you people noone has any idea what this noise might be!!!???
Old Nov 20, 2002 | 05:43 PM
I had a similar problem and it turned out to be LIM gasket,if you have acces to a lift,jack the car up and see if there is any exhaust carbon build up on the bottom of the LIM.
My first did it only on boost than it got worst and you could hear it even on idling engine.
It may not be it but it's worth checking out.
Karel
Old Nov 20, 2002 | 05:46 PM
hey thanks! thats a good idea. ill check there asap. i was also informed that it is possible there is an exhaust leak. that sometimes if bad enough, this will cause the noise too.
Old Nov 20, 2002 | 06:36 PM
Old Nov 20, 2002 | 07:26 PM
Kas_Rx's Avatar
I used to have a MX6 turbo. It was on 12psi and i had the same type of noice. it only came at full boost, but the car just kept going.
I didnt like the sound of it, but i was able to hold boost and nothing broke.
If your worried, dont. If somethings wrong, wait for it to break. It will diagnose itself. Thats what i do.
Old Nov 20, 2002 | 09:13 PM
bump
Old Nov 20, 2002 | 09:19 PM
Mahjik's Avatar
Mr. Links
majikeye,
Sorry I didn't catch ya on the KC forum. You might double check the hoses to the BOV and CRV. I had a faulty hose to the BOV that cause a strange noise ONLY once the car warmed up and ONLY under boost.
Good luck.
Old Nov 21, 2002 | 06:22 AM
Ya,there is exhaust reroute in the LIM so if it is leaking from the bottom you would be hearing exh. noise
Karel
Old Nov 21, 2002 | 09:38 AM
BOV and CRV are ok. i did however notice the noise the other day when the car was cold. now it just seems to be getting louder when it warms up. i can now hear it between 5-10 psi so it is getting worse.
i have a shop available this evening out in marriam but i dont know for how long. i will re zip tie the CRV and BOV just in case. i will also look around on the LIM to see if there is any carbon built up. if there is anything else i should be looking at, let me know.
thanks again for all your help!!!
Old Nov 21, 2002 | 10:32 AM
apneablue's Avatar
What does a cricket or a locust sound like?
Old Nov 21, 2002 | 05:28 PM
you ever ride a bycicle with a baseball stuck in the wheel?
like that...
Old Nov 21, 2002 | 08:02 PM
hey all! just figgered it out. as it turn out, the installer of the motor diddnt put all the nuts on the exhaust manifold (turbo side). it was missing 2 and there was one more loose. two nuts and some tightening later...no more noise and a whole lot less lag
Rotospectre
Mar 28, 2018 03:33 PM
bURGRotary87
Aug 19, 2015 03:54 AM
rexhvn
Aug 19, 2015 02:59 AM
