Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Haltech Maps for 1600 c.c. Secondaries
Old Aug 3, 2001 | 12:54 PM
Talking Haltech Maps for 1600 c.c. Secondaries
Is anyone using Haltech with 1600 c.c. secondaries and 550 c.c. primaries? I am using T-78 turbo I need maps for this set up
answer to bruno@terra.com.gt
Old Aug 5, 2001 | 02:25 AM
MikeL's Avatar
550/1600, T-66.
http://brfoundation.com/RX-7/ML2.zip
Old Aug 5, 2001 | 08:51 PM
Thanks
THank you for charing your map, Will it be possible for you to share de Data log as well.
I am wondering if that is the map tha you are actually using on your car?
Old Aug 6, 2001 | 07:18 AM
MikeL's Avatar
I have a datalog from a dyno run but, I saw in the datalog that the fuel was not right. The map has some fuel changes that were not done while the datalog was being made. You'll see that the datalog was from 05-18-01 and the map is from 05-23-01, shortly after the fuel changes.
http://brfoundation.com/RX-7/ML1.zip
