Bad center ignition coiL??
Old Nov 19, 2002 | 09:58 AM
WONG FRIED RICE's Avatar
R.I.P. GuitarJunkie28
my center ignition coil went bad, replaced that one only. Drove it around for about half an hour...on the way home a couple of blocks away from my house it started going bad again. I stopped, and turned off the car...tried starting it again...had a hell of a time trying, but when it DID start...ran like sh** and wouldn't move, basically no more spark.
Basically what i want to know is...what could be causing my coil to go bad? is it a short somewhere? bad fuse? incorrect size fuse? what is it?? i can't figure it out. I don't want to keep replacing coils, because thats expensive. any help please?
Old Nov 19, 2002 | 10:30 AM
13brv3's Avatar
How sure are you that the old coil was bad? Did it fail the resistance tests, or just didn't seem to put out a spark?
I'm wondering if you have an intermittent bad connection on the harness, and maybe just swapping out the coils moved it around enough to make connection for a while. The new harness is about $57 at Mazdaformance, and it's probably worth changing if you have to go in there, assuming you haven't already changed it.
Good luck,
freq
Aug 21, 2015 03:30 PM
Wolf_
Aug 11, 2015 04:23 PM
