New to rx's. Got some ?'s
Old Aug 3, 2001 | 04:07 PM
Redwood's Avatar
Find Racing
I'm somewhat new to these cars too but I'll tell you what I can (which is very little).
The stock gauges (namely oil pressure) have a tendency to be a bit off but nothing to worry about. Although, if you're putting in a V-8, go all out with a custom cluster or something.
The engine, ecu, etc. will probably get you very little. Your engine is right at that point where it could use a good rebuild so who ever buys it will probably expect to do that and deduct the cost. Worth a little at least.
That's all I know, good luck with the project, even if you are decreasing the rx7 population
