Setting up fuel system
Old Nov 12, 2002 | 09:18 PM
stinkfist's Avatar
Learn to swim.
I'm running a ported 88 t2 motor.
My goal is ~280rwhp with room to go to ~350rwhp in the future.
Can I run the 2 1650cc for secondaries and use stock 550cc injectors for primaries?
Would this do what I need, or should I upgrade the primaries as well?
Thanks,
Mike
Old Nov 12, 2002 | 10:45 PM
qwck10th's Avatar
'lil more info...
Hi Mike,
those injectors should be fine for those HP goals. Assuming: you have the electronics to run them (standalone EFI, or piggyback), enough pump to fill their appetite, and maybe a FPR.
You didn't tell us what turbo you're using, type of port, etc...
Best fuel calculator around, imo, is at RC Engineering. A few clicks in there will help. Search may help too
Believe Ray Hall Turbocharging has some fuel calculators as well.
I think I met you a while back, maybe at the Dynolab, or at Los Reyes.
Cheers,
Steve C.
Old Nov 13, 2002 | 07:03 AM
stinkfist's Avatar
Learn to swim.
Re: 'lil more info...
Originally posted by qwck10th
Hi Mike,
Cheers,
Steve C.
Hey Steve,
I've met you a few times at the meets. I think I talked to you about my 10AE. I sold it though. You coming this thursday? Check the thread I started in the SE section.
I'll be using a E6k to run it. I will have a small street port. I have not made up my mind on wich turbo yet. probably some TO4? . I'll be using the Walbro pump. Haven't decided on an FPR yet either.
Thanks for the info,
Mike
Engine stand ready
Aug 14, 2015 10:26 PM
