Hatch Rattling
Old Aug 2, 2001 | 09:47 AM
ejmack1's Avatar
Lawn Ornament
Hatch Rattling
Anyone have a solution.......
Old Aug 2, 2001 | 03:25 PM
ejmack1's Avatar
Lawn Ornament
I know you guys have a solution for this......
Old Aug 2, 2001 | 05:29 PM
Under PSI's Avatar
I went to Home Depot... bought a rubber connector used for PVC pipes... cut it in half... rolled it up and stuck it on top of the 3rd brake light, on either side of the latch... worked perfect.
-Matt
Old Aug 2, 2001 | 06:32 PM
technonovice's Avatar
Jinx
I just sprayed some lube on it, but I assume you did that first.
Old Aug 2, 2001 | 07:00 PM
ejmack1's Avatar
Lawn Ornament
si there any adjustment or anything i can try tightening???
Old Aug 2, 2001 | 11:44 PM
f2racer's Avatar
Wrap some electrical tape around the thingymabob that holds the hatch down.
Old Aug 2, 2001 | 11:54 PM
ejmack1's Avatar
Lawn Ornament
thingymabob
gotcha
ill put some whatchamacallit on my thingymabob,,
hey but thanks, ill try some of those things tomorrow......
Old Aug 3, 2001 | 12:59 AM
martini's Avatar
I fixed mine with the electrical tape around the hook that hold the latch down (thingymabob)
Old Aug 3, 2001 | 02:11 AM
suganuma's Avatar
no
BAH!
1. lift up hatch
2. loosen hatch hook bolts(on car, not on hatch - little U that it hooks into)
3. push it down as far as itll go.....hold it there while completing step 4
4. tighten bolts
5. slam hatch back down on new lowered hook
6. go drive and notice no rattling because its on there so damn tight
note: if this doesnt work try something else
**you might have to shut the hatch harder after you do all of this, but it wont rattle anymore......at least mine didnt
let us know what works.......
Old Aug 3, 2001 | 04:43 AM
Stevil's Avatar
Mine makes a noise, but its not a rattle. Its more of a sound like when one expells air from the lungs rapidly. I think it might be my shocks for the hatchback. Sound right?
Steve
Old Aug 3, 2001 | 09:53 AM
ejmack1's Avatar
Lawn Ornament
Yeha it soundslike the shocks..... Does it hold your hatch up ok???
Old Aug 3, 2001 | 08:55 PM
Stevil's Avatar
Ya, shocks work fine on hatchback. It might also be compression of some rubber weather stripping, no?
Steve
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
Rotospectre
Sep 13, 2015 11:22 PM
